How many miles on 16" tires?
I'm about ready to get another set of tires for my Ex. Will end up being second set since new. Got 98K out of the factory 16" jobs and sitting on 194K right now on current set and fronts are definitely due. I stayed with the BFG Rugged Trails and think I'll stick with them again getting this kind of mileage out of them on this 4x4 V10.
Anyone experience similar results? How about other brands and those who have gone to larger rim sizes?
I use to work in a tire shop so am familiar with the tipping point between performance vs safety. Currently my fronts are on the edge and that's why I'll likely be replacing them within a month.
I've had plenty of cars with 'performance' tires, they are great for intended use, but not daily drivers when the vehicle is gonna be on the road 25K+/yr. Thats where the BFGs have proved themselves reliable.
I'm more of a BF Goodrich fan because they've never let me down and they are some seriously tough tires with on road manners. My tire of choice is the BF Goodrich All-Terrains.
The BFG Rugged terrains are a dialed back version of the All-Terrains, but have more on road manners. Jdadamasjr ran the original rugged terrains on his '05 up to 100K before he went with the LTX M/S2 or bought another set of Rugged Terrains. So they definitely stand the test of time...
However, since you mentioned Carolina clay, I'd suggest considering BFG All-Terrains. As you probably already know, they have more "teeth" to them and bite into whatever you throw at them. Where other tires slip, BFG All-terrains grip; this is why I had Discount Tire swap my perfectly good Michelin LTX M/S 2 tires for BFG All-Terrains. There were too many times where I had to venture off road and the Michelins weren't cutting the mustard. With BFG All-terrains, off road performance is much better and the truck is definitely more sure footed than with the Michelins.
Just keep them properly inflated to what's on the tire and NOT what's on the door and they will last. (60-70 psi)
As I read that last sentence it reminds me of a trip 2 years ago where I was unintentionally on an off-road trip. I was in the mountains of NC and had dropped off a load of model kits to a fellow who sells online. Anyway I wanted the return trip to be more interesting and less winding so I took a road called Wildcat Mtn Rd. By Google Maps it looked like it was a reasonable road.... yeah... ahem... right. Anyway, I get started on this road, nice blacktop going up the mountain. About 3 miles up I notice the houses thinning and most of them having big rigs with dozers and heavy equipment on them... hmm, must be they like the high elevations (4,000 ft). Now the road turns to gravel, but still decent though narrowing and now only houses to the left (up the mtn) and lower right side sloping more and more away. Yeah... hmm, I'm in my Ex, I'm good, yeah, I'm good...
So gravel turn to dirt.... perfect, lets put it in 4wd, the 'road' must only be another few miles long right?! I start seeing piles of dirt interspersed either side, like a dozer making small inroads. I'm still looking at Google maps now any again, making sure none of these are turn-offs... hmmm, Google doesn't indicate anything like this... hmm.... Guess I'll stay straight. No way I'm going downhill, and uphill? nope! I'm now on a dirt path trees left and right, look ahead, trail (ahem.. wasn't this a 'road'?) now is granite outcrops.... 4WD Low time..... Remember to breath as your going over a dropping granite face....
Thankfully that stretch lasted maybe 200-300 ft? (Not going back to check thank you very much!) Trail has been used by mini 4wheeler ATVs as I can see in the mud at the bottom of the granite run. Hmmm, all the trees, 'hope none is down across the trail... I'm screwed if there is!' And then I start seeing these high corn fields, yeah, corn fields.... hmm, bet some moonshinin' goin' on up 'ere! Hehe... yeah, no way they come to that field the way I did! So white knuckling on the path looking for obstructions, ways out, light at the end of the tunnel, etc. Hmm, nice outcrop of granite overhanging road... looks like a fine future bit of roadwork for someone! So finally the path becomes a trail again and then a dirt road and then bam! Pavement? Wait... I'VE RETURNED TO CIVILIZATION! THERE'S PAVED ROAD HERE! Off goes 4WD and I wave my hands to return the blood to my whited knuckles. Ah, am I glad I was in an Ex and not something else!
I've always run them around factory spec'd 45/55 and never had any front-end issues to cause undo wear. As I said, I put 25K+ a year on them these days so alot of of the hwy mileage.
