Hello all- Need help finding part #'s (both sides of truck) for the flap/ seal that is attached to the top front of rear doors its about 1.5' long. When the front door is closed it closes up the space between them.
IIRC it's 354$$$$$$$$204$$$$$ but someone else should know.
EDIT: Wait, you don'y mean the rubber seal do you, you mean the little flappy thing don't you... I'll do some digging and see what I can find out. Also it should be the same part number for both sides.
The large door bumpers for the 4 regular doors are : YC3Z-2525076-AA. They come in a package of 3.
The rear driver and passenger regular doors also have smaller bumpers mounted on top of inside door..those are part # 374217s . With a little trimming they might also work for the barn door/hatch bumpers. But below is correct part #'s:
The 2 small bumpers for the rear hatch where it contacts the barn doors are part # N805307S. They are discontinued, but i found some old stock through google etc. One to a package, so you need two. Use a dab of silicone when installing to ensure they don't fall out again. <!-- / message -->
<!-- sig --> __________________
