Door wont seal correctly--bent door hinge
Old 04-01-2016, 09:30 AM
jhjr85's Avatar
jhjr85
jhjr85 is offline
Hello!
I have a 2002 Supercrew that I recently got. The guy before me said he slid into a guard rail and ever since then the doors dont seal correctly. Theres a good 1/2-3/4" gap at the tops of both drivers side doors. Doors will shut, but are harder to open.
I tried a couple of things, but nothing has worked yet. I tried to bend the top of the door by pulling/pushing on it. It helped some,but still not completely back to where it should be.
After looking at the door more closely I did notice that the bottom hinge on both doors is not lined up properly. The top one seems right (it runs parallel to the side of the truck) The bottom one looks kicked in, which is right where the guard rail would of hit. I think that this may be my issue.
Is there any way to re-straighten the hinge? I thought about trying to pull the hinge out with a ratchet and hope that it'll pop back in place. Or by putting some sort of shim behind the hinge, to help straighten it back out.
Any suggestions?
Old 04-01-2016, 01:51 PM
kd4gij's Avatar
kd4gij
kd4gij is offline
Get one from the local you pull scrap yard.
JimG1098
16
05-07-2015 06:06 PM
caedo
02-10-2014 08:51 AM
1bad66
01-13-2006 04:40 PM
RidinHIGH
1978 - 1996 Big Bronco
03-24-2005 04:13 PM
tprice73644
10-09-2004 03:20 AM
Quick Reply: Door wont seal correctly--bent door hinge
