Door seal name
Old Feb 3, 2014 | 10:11 AM
caedo's Avatar
caedo
Door seal name
What is the name of the seals at the bottom of the doors that like to fall off of their clips? I'm trying to find some, but I don't know what to call them.
NVM... its just called weatherstripping
Old Feb 3, 2014 | 01:11 PM
whitetmw's Avatar
whitetmw
#20758 - P-34427
Door Weatherstrip, New design - L shaped , Must be mounted on door so when door is closed the L shape closes to a V shape, to make a proper seal. Also push pins must be installed all the way or weatherstrip will be loose.; RH and LH - bottom of front door
Old Feb 3, 2014 | 01:51 PM
Dan V's Avatar
Dan V
Door Seal
Yeah...I see that didn't work. Click the link, enter 20758 in the part number search. $28 and change
Old Feb 3, 2014 | 05:38 PM
caedo's Avatar
caedo
Originally Posted by Dan V
Door Seal
18.99 through AutoNation Ford (Tousley)
And thanks!
Old Feb 3, 2014 | 08:56 PM
crop harvester's Avatar
crop harvester
I found some new plastic clips at Ace Hardware,had to modify slightly & reused the bottom door/mud seals.
Old Feb 3, 2014 | 09:06 PM
Dan V's Avatar
Dan V
Part number by chance?
Old Feb 3, 2014 | 10:01 PM
crop harvester
ok,I got them either at ace hardware or automotive paint store,[W & E] brand p/n 99-1206, they are just barely large enough diameter so I squeezed them with a vice or pliars to tighten up the fit they held real good for two years so far.
Old Feb 10, 2014 | 08:51 AM
wigand13_7.3's Avatar
wigand13_7.3
I just had to replace mine on driver door. Just went ahead to Ford place and they ordered a replacement that came with the clips. It was only $28. Decided it was better to replace whole thing.
green53
Sep 11, 2014 12:06 PM
jvmcc
Aug 12, 2013 08:06 PM
F-100CustomCabTBC
28
May 26, 2013 08:44 AM
1bad66
Jan 13, 2006 04:40 PM
