Need help - ESOF (4wd) not working
Old Oct 5, 2014 | 08:06 PM
jimmer2880's Avatar
jimmer2880
My Excursion is stuck in 2wd. It worked one morning, then it didn't that same afternoon.
I've checked all fuses that resemble a related fuse in the fuse box.
I've replaced the dash switch, Transfer case shift motor and ESOF/GEM module behind the glove box. I've swapped around the relays under the hood on the drivers side fender well.
I ran a hot & ground to the 2-wire plug on the x-fer case shift motor to have it move the ex back into 2wd (replacing the shift motor required me to manually put it in 4hi with a wrench).
At this point, I'm thinking it's a wiring issue? Has anyone else been in this position? Any guidance on where to go next?
Old Oct 5, 2014 | 08:25 PM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
What's not working? Dash light? Hubs?
If it's the hubs not engaging....They're vacuum actuated, I'd start checking lines bud.
Old Oct 5, 2014 | 08:40 PM
jimmer2880's Avatar
jimmer2880
Transfer case isn't engaging.
Old Oct 5, 2014 | 09:07 PM
Krazee Matt
Veteran: Navy
In that case I'd start reading wires in the harness to ensure there are no shorts and no breaks in the wire. Seeing as how you've replaced a lot of stuff already that would otherwise normally be suspect, I'm leaning towards a wiring gremlin somewhere.
secondtonone
Dec 31, 2017 03:03 PM
99F350bigorange
Dec 17, 2014 04:05 PM
roy.prue
1997 - 2003 F150
Jan 12, 2011 06:48 PM
tgr8st
Modular V10 (6.8l)
Jan 15, 2010 11:47 PM
Plugman
Apr 19, 2007 08:02 PM
