ABS light won't go away after new sensor B1230 code
Old Sep 18, 2014 | 08:24 PM
wpwilburt791's Avatar
wpwilburt791
Exclamation ABS light won't go away after new sensor B1230 code
Problem: Initially thought replacing the rear wheel speed sensor on top of the differential would make the light go away on a 2007 F-150 XLT
What I've done already.
-Replaced the sensor
-Used the IDS ford computer to clear the code
-Test drove it for 30 minutes and the light is still on
-Reset any codes by disconnecting the battery
-I have gone as far as swapping a different ABS module thinking it was the problem, after it was re-programmed the module checked out and it wasn't at fault.
It must be a wire, all the fuses for the ABS system are fine.
Has anyone had this issue or traced all the wires and found a common problem such as a pinched wire or melted wire between the module and the sensor? From what I have been researching this code B1230
-bad sensor
-sensor grounding out somewhere
Attempted a multimeter test today and didn't get very far.
Old Sep 18, 2014 | 10:59 PM
P.Bronner's Avatar
P.Bronner
There is also a sensor at each front wheel.
Bigb6.0
Nov 29, 2017 09:58 PM
Oilfan94
Jul 1, 2017 07:38 AM
acapital
Apr 30, 2017 06:46 PM
Jerkys1212
Aug 23, 2016 12:22 PM
Toy4Dad
Apr 8, 2010 02:20 PM
