1952 F1 Screw size for headlight buckets
Old Jun 8, 2014 | 03:12 PM
oscajo's Avatar
oscajo
Cannot find the light assembly schematics for the headlight buckets to grill mounting. Does anyone have the drawing with part numbers or know the different screw sizes?
Thanks,
Oscar
Old Jun 8, 2014 | 03:56 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Here you go.
Name:  Headlight bucket to grille.jpg
Apparently, they're 5/16" -24 x 3/4"
Name:  Headlight bucket to grille2.jpg
Old Jun 8, 2014 | 07:09 PM
oscajo's Avatar
oscajo
I have the correct schematic for my model but it nor yours shows the buckets getting installed or the screw sizes . I could also use the sizes to bolt the ashtray and the speaker grill onto the dash.
Name:  52 front end.jpg
Old Jun 8, 2014 | 11:37 PM
Jolly Roger Joe
Thanks,
Oscar
Your original post says the "headlight buckets to grill mounting". The bolts that hold the 51-52 buckets to the grille, which is p/n 8200, are part number 20347-S in the drawing and 20347-S8 (B156) in the other book. If you mean the bolts that hold the buckets to the headlamp support panel assembly part number 13069, they're also 20347-S.
Old Jun 9, 2014 | 06:15 AM
oscajo's Avatar
oscajo
much smaller screw needed. Maybe I`m calling the part by the wrong name I put a picture to show the two parts needing to be bolted together. The other side of the part takes the screw you showed me. This should help.
Size:  133.2 KB size you told me about.
Old Jun 9, 2014 | 07:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
much smaller screw needed. Maybe Im calling the part by the wrong name, I put a picture to show the two parts needing to be bolted together.
8A-13032 .. Headlamp Adjusting Screw / 1/4" -28 x 2.42" long / Obsolete
32938-S7 .. Headlamp Retaining Ring Screw / #10 -12 x 1/2" long / Obsolete
355768-AS2 .. Speednut #10 / Obsolete
52344-S13 .. Headlamp Door Screw / #8 -15 x 1/2" long (1951/56) / Obsolete
Standard (hardware) parts shown in illustrations may or may not show the complete suffix. The text section is necessary to verify.
Old Dec 12, 2020 | 07:52 PM
jeffgies's Avatar
jeffgies
If you're in a bind or, like me, too cheap to spend more money on shipping than the screws cost, the screws in Dorman kit p/n 42171 (for Fords) will work on a 51. The screws are about 3/4" longer than factory but the threads are correct at 1/4"-28. Also, the screw head diameter is slightly smaller in diameter in the Dorman kit, but it all works out.
Old Jul 15, 2022 | 02:21 PM
smarcelino's Avatar
smarcelino
4wd Low
does anyone make a girl to deflector retainer, I broke a couple in disassembly
Do you know where I can purchase new ones? I broke a few during unassembly ...
Old Jul 15, 2022 | 05:57 PM
burnettd01's Avatar
burnettd01
Go to your local Fastenal store - they can order the fasteners at a fair price.
oscajo
Jan 13, 2014 06:18 AM
Dutch123
1978 - 1996 Big Bronco
May 2, 2007 07:14 PM
sdetweil
Apr 18, 2006 01:30 PM
Jun!or
Apr 17, 2002 01:25 PM
