55 vs 56 headlight bucket depth
Old Apr 16, 2006 | 10:35 PM
sdetweil's Avatar
sdetweil
I know that the air deflectors on the 56 have a dimple in them to allow the headlights to recess a little more, but that also means that the grill bucket must be a little shallower..
Anyone have any measurements of a 56 grill headlight bucket depth?
Thinkin of doing something different for the front grill
thanks
Sam
Old Apr 17, 2006 | 07:23 AM
grncoup's Avatar
grncoup
as i recall the buckets are the same depth, they are set back into the grill on '56's as opposed to being mounted on the outside of '53-'55's. the mounting lip is different on '56's.
Old Apr 17, 2006 | 07:34 AM
sdetweil's Avatar
sdetweil
thanks, but I'm not sure I understood what you said. The air deflectors mount the same, and are flush with the front gravel pan. The grill, with headlight buckets have 3 bolt sockets where the bolts come thru the deflector.
As the fenders are the same, the air dams have to be in the same place on both trucks, so that only leaves the mounting of the headlights in the buckets to reduce the bug eye effect.
If the dimple allows the light to be moved back 1 in, but the bucket isn't shallower, or the headlight mount on the bucket isn't moved back (means the bucket is shallower), then that dimple is useless.
So, something has got to be different.
Sam
Old Apr 17, 2006 | 08:44 AM
AXracer's Avatar
AXracer
The headlite bucket sits further back on the 56, near flush with the front of the grill. The bucket itself can't be shallower or the OEM sealed beam bulb wouldn't fit.
Old Apr 17, 2006 | 09:36 PM
theGman's Avatar
theGman
You can modify the '53/'55 pieces by cutting a hole in the deflectors to allow for the recessed '56 headlight position. You can go all the way and then fab a cover for the hole to keep it dry. If you like fish and your truck is a daily driver, you'll find that a tuna can is about the right size.
Old Apr 17, 2006 | 10:22 PM
sdetweil's Avatar
sdetweil
Ok, I measured my 55 grill headlight bucket depth ane they are 4-7/8 to the mounting surface. can someone measure a 56 grill..
they gotta be smaller to move the bulb back. all the rest of the sheetmetal is the same.
Sam
Old Apr 18, 2006 | 01:30 PM
sdetweil's Avatar
sdetweil
But AX, the dimple in the deflector allows the bulb to sit back further.. thus the grill shell IS not as deep.
It looks like (from pictures) the bulb is recessed in the 56 grill, where it is not recessed on the 55 grill.
so I am trying to figure out how much recessed it is.. or how deep the bucket is to the mount surface..
Sam
53OlderThanMe
17
Feb 23, 2009 07:01 AM
houghda
18
Jun 22, 2007 10:41 AM
delaney
Sep 19, 2006 03:35 AM
Jun!or
Apr 17, 2002 01:25 PM
