High pitched squeal / screech finally found
Old Mar 16, 2014 | 07:21 PM
sand_fiend's Avatar
sand_fiend
For the last 5 months or so,
I have had a high pitch squeal / screech.
It's only after the first start up of the day for about two minutes of driving then all is good.
So i have been thinking that is sounded like the turbo wheel is scraping, or the shaft is about to seize up because of my loss of boost. 25 down to 17 psi. That's what i thought anyway?
I have looked everywhere over and over and have also checked the wheel twice for play. it's all good and snug.. (spins free)
So today i finally had a chance to dig in to it with the leak detector cap that Trey made for me. i soaped the living bajesus out of everything and saw nothing but i still thought i could hear a slight air leak somewhere.
about an hour in to it i found two things,
On the red line where it splits from one to two lines, the rubber had rotted away and was leaking..
Then also, on the boost line where it connected to the T line was cracked and leaking.
Fixed, started and test drove.. No more screaming !
My boost is back to 23 but i can see the up's are leaking now..
I have a set of dormans ready to go on but i want to install a surge wheel while the turbo is off..
Anyway, for now the motor is nice and clean !!
Old Mar 16, 2014 | 08:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Glad you got it figured out Phil! Let me know how those Dormans work out. If you need a hand, I'm just a phone call away!
Old Mar 18, 2014 | 08:29 AM
snknby123's Avatar
snknby123
Nice job finding the leak Brotha! Why did the noise go away after it warmed up a bit? Just curious.
Old Mar 18, 2014 | 08:51 AM
Jesser02EX's Avatar
Jesser02EX
Does anyone know what the Red and green tubes are called? I need to replace them as the rubber is badly damaged. The green goes into the pipe from the filter and the red goes to the actuator on the turbo. I can find all the parts but that tube coming from the solenoid.
thanks,
Old Mar 18, 2014 | 10:10 PM
sand_fiend's Avatar
sand_fiend
My tubes were good so i just replaced the rubber 90's.
Bought them at the local auto parts.
The vacuum line form the boost gauge had a very small hole from rubbing.
I believe when it got warm, the tube softened up and closed the hole.
i just cut the tube at the hole and put a plastic line splicer in it
Old Mar 18, 2014 | 11:21 PM
scotttahoe's Avatar
scotttahoe
I was at Ford about a couple of months ago to replace those red and green lines and as far as they told me they do NOT make them anymore so don't break them or throw them away!!!
Old Mar 19, 2014 | 08:12 AM
Jesser02EX's Avatar
Jesser02EX
Wow, these trucks will be run off the road by Ford!
Do we even need the Red Line? I remember thread about people who would unplug it for extra BOOST.
Phil,
Do you know what parts store you went go, or what you asked for with regards to the rubber 90's? I need one.
Old Mar 19, 2014 | 11:04 PM
sand_fiend's Avatar
sand_fiend
I went to auto zone. They are by the motor oil. They are on the wall by the other assorted fittings, rubber plugs, oil drain plugs, exc.
The guys behind the counter were clueless..
The do sell hard line also, but it is a roll of straight line.
I called Clay and asked him if he sold them. He dose not. He said it ok just to plug them all..
Old Mar 20, 2014 | 12:12 AM
scotttahoe's Avatar
scotttahoe
Nice to know.
ldfry001
Jul 27, 2012 10:24 PM
Robert6401
34
Mar 12, 2010 12:28 PM
WideOpenFord
Nov 22, 2009 01:12 PM
crack
22
Oct 2, 2007 01:34 PM
rosa70
18
Jun 17, 2004 10:12 PM
