Ideal scangauge II readings
Old Feb 18, 2014 | 06:29 PM
nodesy's Avatar
nodesy
So I have been poking around trying to find information on the "healthy" readings for the 7.3. I just programmed my scangauge II and would like a starting reference point. Any help?
Thanks!
Old Feb 18, 2014 | 07:25 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I doubt anyone is going to list ALL of the values you can pull with a ScanGauge.
Anything specific you are looking at?
Old Feb 18, 2014 | 07:45 PM
nodesy's Avatar
nodesy
Seems like there are only a dozen or so that I was able to get readings for. I guess among the ones I am most concerned about are fuel pressures and boost.
Old Feb 18, 2014 | 08:25 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Im not familiar with Scan Gauge but the PCM is able to report a TON of readings.
Fuel pressure should be 55-65psi, and boost should max out around 19psi for a stock truck, 26ish PSI for a tuned truck.
Old Feb 18, 2014 | 08:28 PM
acf6's Avatar
acf6
Scangauge 2 doesnt report fuel pressure as the PCM does not read that, and the boost gauge on the scangauge is meh. I have a scangauge that i use for ECT/EOT/FICM/Volts and analog gauges for Fuel pressure/EGT/boost
Scangauge i also use occasionally for ICP, IPR, VGT (guess you dont really need that),
Old Feb 19, 2014 | 04:10 AM
Tugly's Avatar
Tugly
We don't have the FICM either... or that ECT. No Fuel Pressure, Engine Coolant Temperature, or Exhaust Gas Temperatures on the OBDII port.
Engine Oil Temperature, Injector Control Pressure, Injector Control Pressure Duty Cycle (IPR), Fuel Injector Pulse Width, Boost or MAP, Exhaust Back Pressure, Transmission Fluid Temperature, Torque Converter Slip, and Volts are good troubleshooting PIDs. I doubt you'd want to monitor all of that, so now it's down to "What do you want to monitor?"
jonbar87
15
May 24, 2017 06:46 AM
nissandoc
Oct 26, 2009 08:58 PM
gmm
Mar 6, 2009 02:50 AM
matt71
Aug 25, 2008 07:12 PM
scatgo
26
Nov 15, 2007 02:01 PM
