Edelbrock Carb Base Gasket
Old Feb 2, 2014 | 06:38 PM
Branded's Avatar
Branded
What does using a 3/8" thick gasket achieve vs using the normal thin gasket.
Old Feb 2, 2014 | 06:46 PM
jthesby's Avatar
jthesby
Helps to keep the fuel cooler in the carbie bowls. Cooler/denser air/fuel charge, more power, right?
Old Feb 2, 2014 | 06:48 PM
Branded's Avatar
Branded
That makes sense. Thanks
Old Feb 2, 2014 | 06:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think it's for power, it's just to reduce the amount of fuel that boils out when you stop. Then you don't have to crank as much to re-start. I've used 3 regular gaskets on a Holley 94 (stock carb), it helps. But mostly because the stock flathead intake manifolds have an exhaust heat riser under the carb.
Old Feb 2, 2014 | 06:57 PM
Branded's Avatar
Branded
I'm tearing down everything under the hood to detail and paint. Im replacing the Edelbrock RPM intake with a Edelbrock RPM endurashine on the 302. The intake on the truck had a 3/8 thick gasket under the carb. I've run several Edelbrock carbs before and never run a thick gasket and never noticed and issue with heat soak to the carb. I'm thinking I'll just use 2 of the regular thin gaskets.
Old Feb 2, 2014 | 07:32 PM
53FOPAR's Avatar
53FOPAR
Yeah, it's to keep the heat away from the carb bowls. I am running a 1 inch plastic spacer under the carb for the same reason.
mrpotatohead
19
Jul 5, 2017 06:20 PM
mac10guy
Mar 4, 2010 07:52 PM
mkdubs
Jan 3, 2010 10:07 AM
Chumbucket
Mar 18, 2008 02:56 PM
Fomoko1
52
Mar 13, 2008 01:55 AM
