carb gasket
Old Jan 2, 2010 | 03:02 AM
mkdubs's Avatar
mkdubs
carb gasket
I have an edelbrock 650 carb on my truck, and on the drivers side under the linkage im leaking fuel on to my intake manifold, so my questions are can i just unbolt the 4 bolts and pull my carb off, and also what kind of gasket do i use? I also have a carb spacer but not sure what brand, is there a certain gasket to use for the spacer and manifold? sorry the questions are so cluddered together!
Old Jan 2, 2010 | 10:24 AM
wdfp's Avatar
wdfp
An Edelbrock does not have a gasket below the fuel level in the bowls. It must be coming from above and running along the throttle shafts which are probably sloppy if its very old at all..
Old Jan 2, 2010 | 06:09 PM
mkdubs's Avatar
mkdubs
well that just sucks.....do i need to rebuild the carb then? Its about 4 years old
Old Jan 3, 2010 | 10:07 AM
wdfp's Avatar
wdfp
Depends on why its leaking and how loose the bores are, the last edelbrock I ran went about 3 yrs and it was done, does it leak while running? Probably not sutting fuel off with the float, chunk of something holding it open a little would be my guess, too much fuel pressure pushing the level to high possibly. probably wouldn't run if it did that for very long, so I am guessing it does it after shutting it off. Could be the same thing or fuel level is too high also from an improperly set float..
