Driver window fell off track - cables not in tandem
Old Jan 6, 2014 | 11:18 AM
Jim Ray's Avatar
Jim Ray
Hello everyone!
I am in GA and we just got our first REAL freeze of the year (Currently 27 out). On the way out this morning my wife tried to roll the driver side window down and realized that the window was stuck.
She stopped at conv store for coffee and as I sat awaiting her return the window unstuck and fell all the way down.
I've taken the panel off and found that:
A - the plastic clip on the left track is now cracked and loose
B - the cables do not move in tandem - the left one goes up and down, but the right one stays at the bottom. As the left one goes up, I can see the cable unwinding out of the bottom of the motor, as it goes up the left side tightens up and stops half way.
C - there is still some lubricant on the track, but I will be adding more.
I am in between jobs, so taking it somewhere is out of the question.
Question - Ideas on what the issue may be, and how can I repair this?
I am mechanically inclined, can do most anything myself, but a tut or walk through would be appreciated as I don't want to have to do this again later.
For now I have placed two 2x2 boards in place to hold the window up and left the panel off (I plan to attack this the day after tomorrow when the temps are above 40 again).
Thank you in advance!!
Old Jan 6, 2014 | 11:49 AM
makuloco2000's Avatar
makuloco2000
You need a regulator the cables wrap up or break all the time. Tape up the window and swap out the regulator.
Old Jan 6, 2014 | 01:15 PM
Jim Ray's Avatar
Jim Ray
That also causes the window to roll up slowly, correct?
And thank you!
Old Jan 6, 2014 | 02:50 PM
makuloco2000
yes it will as the cable chews up in the spool we change them all the time here.
cbrown9064's Avatar
cbrown9064
I have found that spraying the window felt with silicone spray helps the slow roll up when cold a lot. It is -20 here today and my drivers window rolls up much faster since spraying the felt. Leaves residue on the edges to the glass, but what the heck.
So after replacing your reg, spray the felts also.
CB
Old Jan 6, 2014 | 02:58 PM
Jim Ray's Avatar
Jim Ray
Thanks, guys - I'll get on it as soon as the temps rise back up lol
Old Jan 6, 2014 | 07:21 PM
makuloco2000
CB
We do the same thing it helps in the long run
Old Jan 6, 2014 | 07:42 PM
alloro's Avatar
alloro
Check eBay for the regulator with and without the motor. I've actually found regulators with the motors for less than what auto parts store sell just the regulators for. I would've looked it up for you but you never told us what vehicle you have.
homesteader
2004 - 2008 F150
Sep 27, 2010 06:52 PM
Lobo
Feb 15, 2010 11:41 AM
putter
Jan 30, 2010 04:41 PM
fordtrkpuller
Mar 7, 2005 09:35 PM
