Suddenly out of nowhere my driver side window has stopped going down. It seems as if the window would go up as the interior lights dim when I hit the switch.
I took the door apart and jumped the window motor and it worked in both directions so I thought I just needed a new switch. After replacing the switch the window still wont go down (all other windows are fine). Could it be the GEM doing this? Anyone else had a problem like this? Any advice here would be great. Thanks
Back when I had my 97 Expedition and before I had the windshield resealed, after a heavy rain or a car wash I would have issues with the window not going down. A couple of warm days later it was all dried out and the window worked perfect again.
Unfortunately it had not rained for a while here when the window stopped working. Its been over two weeks already and there is no change.Where does the windshield leak? I want to fix this permanently.
Well I used the search feature and got nothing about where the leak is
The whole windshield has to come out, the surfaces cleaned, then it get's reinstalled correctly. I suggest going into an auto glass shop and having them do it so that it comes out right. It doesn't take much to damage a windshield if the installation is off just a hair.
Yes. After removing the kick panel I found the door harness plug had gotten wet and rotted. I replaced the plug with one from the junkyard and the window works again
