2000 navigator
Old May 20, 2015 | 09:55 PM
adamrich33's Avatar
adamrich33
2000 navigator
I just installed an after market stereo and now I'm blowing fuse #2 which is for climate control, clock, pcm. With the fuse blown my climate control goes crazy and service light comes in but my truck will run and drive normal. If I disconnect the factory amp harness from the stereo the fuse doesn't blow. And the factory amp doesn't work so I'm thinking it completely failed when I hooked up the new stereo and that could be my issue with fuse 2. But with out a wiring diagram I'm in the dark. Does any one have electrical diagrams they are willing to share?
Old May 21, 2015 | 03:13 AM
alloro's Avatar
alloro
What does this wire do that you connected to fuse #2?
Old May 21, 2015 | 06:49 AM
adamrich33's Avatar
adamrich33
There isn't a wire that I'm using for the stereo that is connected to to the fuse 2 that I'm aware of. Other than the wire from the stereo for the steering wheel controls which I'm not using that wire either. It was supposed to go to pin14 on the factory harness
Old May 21, 2015 | 10:04 AM
alloro's Avatar
alloro
If the problem started when you installed the stereo then something from the stereo is connected to that fuse. Here is what you do, with a meter or test light and a good fuse in the #2 spot, test each and every wire at the stereo harness plug for power. Then remove fuse 2 and do it all again. Whichever wire (or wires) that loses power is the one tied to fuse #2. Doing that might give us a clue as to what the problem is.
Josh29
Jun 24, 2018 01:15 AM
Don Manning Jr.
2009 - 2014 F150
Feb 12, 2018 11:52 AM
greenbuckfifty
1997 - 2003 F150
Dec 7, 2008 07:48 PM
gaspowerSD
Jul 10, 2008 06:20 PM
JoshsFord150
Mar 16, 2004 10:09 PM
