Name That Part
Old Dec 25, 2013 | 02:47 PM
TKegs763's Avatar
TKegs763
Name That Part
Merry Christmas guys. I decided to take the free time today and try to track down my fuel and oil leak. I'm pretty sure it's the orings on my fuel drain, so when I looked down there I noticed two things. The first thing I noticed was that I am missing a torx screw right below the drain. The second thing I noticed was this tube next to the place where fuel drains out when you open the lever. Where does it go? My truck never has ran very good since I bought it and I really want to enjoy it.
Old Dec 25, 2013 | 02:48 PM
TKegs763's Avatar
TKegs763
BTW thank you in advance and God bless!
Old Dec 25, 2013 | 02:57 PM
Mowing Man's Avatar
Mowing Man
That rubber hose not connected to anything slips over the barb in the back if the fuel bowl. When you open the drain, the fuel should flow out the barb/nipple, through that rubber hose into a steel line, and then drain out from under the engine off the crossmember. What do I win, lol?
Old Dec 25, 2013 | 03:03 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
Can't really see the torx, but its probably one that holds the drain valve to the filter housing. The rubber hose is the drain hose, and belongs on the metal tube to the left of the hose. The missing torx is probably part of your leak problem. That and its likely do for an oring change.
Old Dec 25, 2013 | 03:46 PM
jasonc76's Avatar
jasonc76
Mowing man is correct. Fuel drain tube.
Old Dec 25, 2013 | 04:37 PM
TKegs763's Avatar
TKegs763
Thanks for the help guys! Now I need to find my oil cooler lines. It leaks like crazy in the morning until it warms up, but everything is so covered in oil I can't pinpoint where it's coming from. I'll start a new thread for that. Oh, and Mowing Man I wish I had a prize for you! Lol
Old Dec 25, 2013 | 04:48 PM
Mowing Man's Avatar
Mowing Man
Hahaha, the Merry Christmas you wished us all was good enough for me! I'm glad I was able to help a little bit after all the info and assistance I've received from all you guys!
Old Dec 25, 2013 | 04:52 PM
Pikachu's Avatar
Pikachu
There aren't any lines to the oil cooler, per se; it's bolted to the side of the block. The oil filter attaches to the back end of it.
Old Dec 25, 2013 | 04:54 PM
TKegs763's Avatar
TKegs763
Any idea where the oil might be coming from? Started doing this during icemageddon a few weeks back.
Old Dec 25, 2013 | 04:56 PM
Pikachu's Avatar
Pikachu
It could be the o-rings in the oil cooler. It's a messy job to change them, but not a difficult one.
Old Dec 26, 2013 | 06:20 AM
Tugly's Avatar
Tugly
Originally Posted by TKegs763
...It leaks like crazy in the morning until it warms up....
EBPV is active when cold and just sits when warm. Look at your turbo pedestal.
Old Dec 26, 2013 | 08:33 AM
th67ss's Avatar
th67ss
If it only leaks oil when it's cold I'd say it's your oil cooler. Most of the leaking should be around the left side of the truck, at least that's where mine was.
Old Dec 26, 2013 | 08:38 AM
TKegs763's Avatar
TKegs763
There is a little bit of oil by the EBPV, but it is dripping if not running out by the drivers front of the truck.
Old Dec 26, 2013 | 08:39 AM
TKegs763's Avatar
TKegs763
Where is the oil cooler?
Old Dec 26, 2013 | 08:46 AM
Tugly's Avatar
Tugly
It's that great big tube next to the driver-side exhaust manifold. It goes from the oil pump to the oil filter, but you have coolant and oil in the tube... so don't do anything with it until you have a plan and parts.
