Sucking air into fuel line
Hey Everyone,
I have a '99.5 f350 7.3 and its pulling air at about 1/8th - 1/4 tank. I believe the pick up must have a crack in it. Its been awhile since I've been on here and I know there is a fix but, I can't seem to find it. Can someone help me out with this problem?
I'll be going from Fl. to Iowa on a hunting trip soon and need to fix my fuel issue before I go.
Thanks in advance,
Dave
Thanks in advance,
Dave
You are probably thinking of the hutch mod, you likely have a cracked pickup foot so you would need that too, unless you wanted to do a sump setup instead of the lift style.
http://www.guzzle7pt3.com/hutch.php
i'm thinking that it is only pulling air when the tank is low. It started the first time at about 1/8th of a tank so I would fuel up at 1/4 tank. But, one day it started to buck at 1/4 tank so i try not to let it get too far below 1/2 tank now. I have to say, it feels better at the gas station when i fill from there, I feel like I'm not spending as much! I just have to do it twice as much. I digress.
I wonder if the foot has fallen off?
if your gonna drop the tank to fix the pickup foot i'd definitely recommend going with a kit to do the hutch/harpoon mods at the same time. I used the kit from strictly diesel and I really liked it. it came with a pre pump fuel filter/water separator as well. Just make sure your tank is empty before you try to drop it.
Thanks Jason,
I was just talking with a buddy and he said the same thing "while you're in there you might as well...." It hit me then to not to try to go the cheep route. Question, I can't run the fuel below 1/4 tank, how do you get the rest out? I will have to leave about 3/8 in it so it doesn't suck air and I'm not sure if I can get a siphon hose in there. I have to admit I haven't tried yet.
