1997 expedition dies after starting
Old Oct 7, 2013 | 11:39 AM
jawsok's Avatar
jawsok
1997 expedition 4.6l 4wd starts and then dies almost immediately. Any ideas on where to start?
Old Oct 7, 2013 | 12:31 PM
timbersteel's Avatar
timbersteel
Any tune-up performed? Sounds like weak fuel pressure.
Old Oct 7, 2013 | 12:40 PM
alloro's Avatar
alloro
Once it starts, slightly press on the gas pedal to raise the idle. Does it still stall then, or only at idle?
Old Oct 7, 2013 | 01:37 PM
Icefan71's Avatar
Icefan71
I had the same problem. If I gave it gas it would stay running. If I let it idle it would die. I had a bad IAC, idle air control valve. I replaced it and that fixed the problem.
Old Oct 7, 2013 | 08:01 PM
jawsok's Avatar
jawsok
It will run rough if I press on the gas pedal. I will check on everything everybody told me. Thanks on all comments. I will let you know in the next few days
carlos813
Florida Chapter
Aug 5, 2013 06:10 AM
gregnorwood
Jun 14, 2007 01:34 PM
BlacJack
18
Sep 14, 2004 07:58 AM
gkateley
May 5, 2002 05:59 PM
shomby
Nov 17, 2001 04:09 PM
