Upfitter install
Old Sep 16, 2013 | 10:05 AM
cdrich07's Avatar
cdrich07
Upfitter install
Finally found a use for the up fitter harness and switches I've had lying around the past year or so. First, I found a spot on the PS resivoir that places the relay's right above the existing relay's under the hood on the L side near the firewall. One hole drilled into the mounting bracket for the relay holder and it bolts right in. Second, instead of trying to figure a way to make it plug into the fuse box I cut the connector and ran a hot wire to the six wires as I want to use the switches without a key anyway. Right now I have them direct wired to the battery and have LED driving lights on the #1 switch. Third, I found the diamond shaped plug to run the switch plug through the firewall and into the area below the driver side dash. Once through, I replaced the plug and routed the wire through the precut area in the isulation on the interior. No cutting and still maintains a good seal. I haven't decided where to place the switches yet due to I will need to do some cutting so I now have them on the dash behind the tilt handle of the steering wheel. The thing I like about this setup is that the blunt cut wires are under the hood and I do not need to run anything else through the firewall. I also still have the use of my 4 pass throughs that Ford has in place so that gives me access to 8 wires already through my firewall and no modifications to the firewall.
I couldn't load pics off my iPad to this post but I do have pics in an album titled Excursion up fitters in my garage. I'll update once I figure where to permanently install the switches. Hope this helps.
Old Sep 16, 2013 | 01:17 PM
Stewart_H's Avatar
Stewart_H
Check out the DIY upfitter switches install thread in the Tech Folder for ideas.
Stewart
ZonaNavyStar
6.7L Power Stroke Diesel
Dec 2, 2014 09:00 AM
dthomas24
Dec 23, 2013 01:23 PM
robles4242
16
Oct 4, 2010 12:20 AM
Rollin03F250
Electrical Systems/Wiring
Nov 20, 2009 03:09 PM
Dynaridernc
Mar 27, 2009 09:25 AM
