Ford says the no start is due to code P1283
Old Jul 9, 2013 | 03:13 PM
rolltide3006's Avatar
rolltide3006
After the truck being at the dealership for about a month I finally got some headway. Apparently my no start is due to code P1283 which I was told is an electrical code for the IPR. Does anyone have any experience with this issue. He made it sound like I'm going to have to look at all the wiring going to and from the IPR. Is there any chance it's the solenoid?
Old Jul 9, 2013 | 03:54 PM
Hussler's Avatar
Hussler
1283 = Output circuit detected during Standard test, indicates high or low resistance in circuit.
Check the electrical plug that goes to the IPR. Most likely it's in that area. Diesel fuel and oil tends to leak on that plug melting the wire insulation causing a short or open connection.
Old Jul 9, 2013 | 04:42 PM
pilgrimbizket's Avatar
pilgrimbizket
When you are inspecting wires for a shorts what do I look for??
Old Jul 9, 2013 | 04:49 PM
Hussler's Avatar
Hussler
Bare wires touching each other or grounding to engine block.
Old Jul 9, 2013 | 09:00 PM
rolltide3006
Ok so there's no chance it's the solenoid?
Old Jul 9, 2013 | 10:14 PM
fordpride's Avatar
fordpride
It could be the solenoid but its most likely wiring around the fuel bowl
PigFarmer
Dec 9, 2021 04:45 PM
Villengineer
Sep 30, 2014 03:53 PM
Two000F250
Oct 6, 2013 12:10 PM
dtperformance
Dec 8, 2011 07:27 PM
BURNSTOUGHFORD
1997 - 2003 F150
Jun 25, 2008 06:48 AM
