2006 Expedition LOW idle rpm leading to stalling
Old Jun 17, 2013 | 01:04 PM
shadetree1980's Avatar
shadetree1980
Hi guys, my '06 Expedition idles at a very low rpm (about 250-500 rpms) and it seems to have a slight lope to it when idling. It also has a tendency to stall when you slightly using the throttle, for example pulling into or backing out of a parking spot. It started doing it about a week or 2 after I replaced the coil packs and plugs. I have also replaced the fuel pump drive module. The fuel filter was changed about 12,000 miles ago, and I use injector cleaner about every 2-3 oil changes. Any ideas? Thanks in advance for any input!
Old Jun 17, 2013 | 01:49 PM
pinellas50's Avatar
pinellas50
You may need to do a throttle body service. Basically wipe out all the carbon buildup in the throttle body where the throttle plate makes contact with the sides. Carbon can build up there and not allow the engine to get enough air to idle. You can clean it out with a rag and a can of throttle body cleaner most of the time.
Old Jun 17, 2013 | 03:59 PM
shadetree1980
Thanks, I'll give that a try as soon as I get home and let you know what happens.
Old Jun 17, 2013 | 06:33 PM
shadetree1980
I pulled off the intake and cleaned the throttle body like you said and now, no more loping when idling and throttle response is a lot better. I haven't ran it long enough yet to see if it still wants to stall out, but I think it worked. Many thanks for the tip!!
jnealhicks
Modular V10 (6.8l)
Aug 20, 2017 09:15 AM
Superduty450
2004 - 2008 F150
Mar 25, 2015 06:15 PM
Stockbuilder
1983 - 2012 Ranger & B-Series
Sep 27, 2014 03:10 AM
Dustin1690
Aug 14, 2011 03:51 PM
theman79
Nov 10, 2006 11:18 PM
