Cleaned throttle body
Old Sep 26, 2014 | 12:22 PM
Stockbuilder's Avatar
Stockbuilder
My 98 Ranger has 90k on the odometer. It has the 2.5 engine and manual transmission. throttle body had never been serviced. The idle speed was down to 500 RPM and with the air conditioner on would hunt between 500-700 RPM. Kind of like a soft surge. I pulled the assembly and yuk! It was loaded with soft carbon. I used CRC Teflon safe Throttle body cleaner and a soft bristle brush to clean it. Idle is rock steady at 700 RPM with or without the compressor engaged. Throttle response is smoother and the engine even sounds quieter. Drivability is much improved. If you are having idle issues I'd recommend doing this service. It's easy to do and is cheap in the bargain.
Old Sep 26, 2014 | 10:28 PM
BusBoy52's Avatar
BusBoy52
soft carbon
Can you tell me what you mean by the term soft carbon?
Old Sep 27, 2014 | 03:10 AM
Stockbuilder
As opposed to dry, hard and brittle carbon.
Russ8393
Jan 29, 2007 09:04 PM
htcsusn
Jun 11, 2006 08:05 AM
puck1263
Nov 1, 2005 10:04 AM
gdoggy
Jun 19, 2003 03:15 PM
Schlump
1978 - 1996 Big Bronco
Feb 19, 2003 10:37 AM
