05 navi trans fluid
Old Jun 13, 2013 | 12:54 PM
Kevin 1988's Avatar
Kevin 1988
05 navi trans fluid
My dads 05 navi leaked out 4 quarts of tranny fluid yesterday he refilled it after noticing a huge puddle an fluid trails an since then it hasn't lost anymore fluid does anybody have an idea about how this could happen
Old Jun 13, 2013 | 03:56 PM
pdqford's Avatar
pdqford
Where is it leaking from? Maybe a picture of the leak my help with responses.
Old Jun 13, 2013 | 05:11 PM
68bluebeast's Avatar
68bluebeast
I am in the same boat right now with my 01 navi, where did his leak from?
Old Jun 17, 2013 | 08:49 AM
Kevin 1988's Avatar
Kevin 1988
Well we pulled the tranny an changer the pump gasket and now the speedo an odometer isn't working
Old Jun 17, 2013 | 09:31 AM
alloro's Avatar
alloro
You missed a connector.
Old Jun 17, 2013 | 10:04 AM
Kevin 1988's Avatar
Kevin 1988
I checked that twice there's four two small blk plugs a white plug an the plug on the shifter I was reading something about resetting the PCM do u kno anything about that it odometer isn't working either
Old Jun 17, 2013 | 10:38 AM
Kevin 1988's Avatar
Kevin 1988
Old Jun 17, 2013 | 04:51 PM
Kevin 1988's Avatar
Kevin 1988
Just unplugged everything an replugged it took it for a ride an the speedo jumps up then bk to 0 an when the speedo works the odometer works any ideas
Old Jun 17, 2013 | 05:40 PM
alloro's Avatar
alloro
I never heard of a need to reset the PCM, but if you must all you do is disconnect the battery for a few minutes to reset it.
Old Jun 17, 2013 | 05:42 PM
alloro's Avatar
alloro
Still sounds like a bad connection, or perhaps the sensor itself was damaged during the tranny R&R.
Old Jun 17, 2013 | 07:17 PM
Kevin 1988's Avatar
Kevin 1988
Just ran a dionastics test cuz the CL light popped on an it's a speed sensser thanks for your help alloro
copyman1
Apr 25, 2013 01:06 PM
CoogFx4
Jun 20, 2009 12:23 PM
ripcurl94
Jan 10, 2006 01:08 PM
silverxlt
Feb 4, 2005 07:44 AM
