Whys one tire wearing like this?
Old May 12, 2013 | 07:02 PM
cabloom300's Avatar
cabloom300
I noticed my front right tire is wearing weird all over. Its like chunks have been taken out and not a constant wearing issue. Again this is only on the front right. Could it be the ball joints are going? Thanks
Old May 12, 2013 | 07:56 PM
F350-6's Avatar
F350-6
It's likely a worn suspension part. Shock, ball joint, tie rod end, bushing, etc.
Old May 12, 2013 | 07:59 PM
pin8246's Avatar
pin8246
My right driver was doing this, and mine I found a bent leaf spring bracket. Not typical, but as stated above a suspension part.
Old May 12, 2013 | 08:14 PM
Kdr358's Avatar
Kdr358
It looks like you may have a cracked leaf spring in the front, They seem pretty separated near the front bracket. Do you have any wobble or vibration?
Old May 13, 2013 | 09:13 AM
cabloom300's Avatar
cabloom300
After looking, my front right shock is shot. Theres no bottom bushing at all. Is this enough to cause this? I need to get my truck inspected this month so hopefully i can look into this a little more.
Old May 13, 2013 | 12:11 PM
garydmundy's Avatar
garydmundy
I had this happen on my H1 Hummer but it was both front tires. Turned out to be my shocks.
Old May 13, 2013 | 12:27 PM
Kdr358's Avatar
Kdr358
I still would inspect the front shackles where the springs bolt in, I still think it looks like a broken spring. If it is broken that would explain why one shock is bad and I assume your talking about the bump stop being almost gone. If a spring is broken it will not pass inspection. Poke around with a flashlight and look closely at the springs in front and behind the U bolts. Factory springs shouldn't look like that.
Old May 13, 2013 | 12:30 PM
Smokiesman's Avatar
Smokiesman
When you think what a shock does and how it works it could very well be your problem!!
Smokie
mountain dewd
15
Jan 12, 2018 10:06 AM
WorkhorseF250
Jul 3, 2010 07:56 PM
Jzinkiewicz
May 11, 2008 03:41 PM
nicki18
1997 - 2003 F150
Feb 12, 2004 06:37 PM
dfawvor
Aug 21, 2003 10:01 AM
