Steering column/pedals floor plates
Old Apr 4, 2013 | 05:32 PM
Greg M-47's Avatar
Greg M-47
My 1949 mercury had no floor plates around the steering column and the brake and clutch pedals when I got it. I found some plates at a swap meet and then got the insulating pad and other from Dennis Carpenter.
Can anyone give me some guidance as far as installing all this stuff please. Some do's and don'ts. What order do they all go in etc. Any pictures would help too.
Thank you for any help.
Greg M-47
Old Apr 4, 2013 | 06:27 PM
oldmerc's Avatar
oldmerc
oldmerc
Lower plate goes in first then the upper plate overlaps it then the seals for the pedals as I recall . Insulating pad and rubber floor mat next then the rubberized trim piece that fits around the steering shaft .
If I have that wrong I am sure some one will correct me .
Old Apr 4, 2013 | 07:03 PM
Greg M-47's Avatar
Greg M-47
Okay, that's a help. I've got to have the steering box and shaft not bolted in so I can slip the insulating pad and the floor mat and the rubberized trim piece for the steering column. into place. Then try to slip the steering column outer cover with the mounting clamp over the steering shaft. Sounds like a two man job for next Monday. Thank you for the reply. Any other words of advice ?
Greg M-47
Old Apr 4, 2013 | 08:03 PM
49m47's Avatar
49m47
Greg I emailed you some pics. I hope they help.
Dave
Old Apr 4, 2013 | 08:52 PM
49m47's Avatar
49m47
I have spent the last 2 weeks trying to cut a new carpet to fit. It is much more difficult then I thought it would be
kevintoupin
16
Jun 22, 2017 04:30 PM
78150custom
Sep 9, 2009 12:04 PM
hivolt5.0
Feb 4, 2009 01:03 PM
mk
Nov 5, 2002 06:05 PM
19Seventy7HiB0y4x4
16
Mar 20, 2002 09:12 PM
