Timken axle question
Old Apr 1, 2013 | 08:47 AM
MarkG.'s Avatar
MarkG.
What is the difference between the 6.66 and 6.67 axle ratios? are they the same? this is confusing the ________________ out of me. my 52 owners manuals and 48 to 52 repair manuals tell me two different things. thanks. Mark G.
ps. the space above is a "fill-in-the-blank".
Old Apr 1, 2013 | 09:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year is the truck, what series is it? There's more than just one Timken rear axle.
Your "About Me" profile says 2003 F150, obviously not what the Timken is in.
You should list your trucks as a signature, so others will know what you're working on.
Old Apr 1, 2013 | 09:14 AM
MarkG.'s Avatar
MarkG.
Sorry. my truck is a 51 ford f5. im converting it to M-H. if the 6.66 and 6.67 ratios are the same then i wouldnt have to swap out my rear axle. thanks. Mark G.
Old Apr 1, 2013 | 09:27 AM
raytasch's Avatar
raytasch
Believe Nothing
For any time you will be, should be in 4WD the .01 ratio difference will make no difference. I see this type difference listed between front and rear ratios.
Old Jan 7, 2022 | 05:35 AM
m4rkeyviusc4they's Avatar
m4rkeyviusc4they
Old thread but I do not care:
Don't think their was a ford 9" in 87-96 trucks (pretty sure they stopped in 84ish but not 100% sure as I stopped hanging around the bullnose club when we got rid of our 86) however a lot of people like to stick 9" rears in the 87-96 trucks and 40s trucks I believe. That is what I would personally do at least.
Old Jan 8, 2022 | 09:05 AM
arthall's Avatar
arthall
As a retired transmission engineer, I can tell you there is no gear set that would give you such a small difference. The actual ratio is likely 6.666666 and could be expressed as either 6.66 or 6.67. An example gear set giving that ratio would be a 9 tooth pinion and a 60 tooth ring. I'm sure you would be safe to assume both stated ratios represent the same gear set.
Old Jan 8, 2022 | 09:24 AM
51fred's Avatar
51fred
I used to have a 1959 factory 4x4 before my 51. (I should never have sold ) It had a 3.92 front axle with a 3.89 rear axle. Unlike newer vehicles it was never intended to run on dry roads on 4wd.
Wish I had a picture of my beast!
troverman
Dec 16, 2014 07:04 AM
Ranger Bob
2004 - 2008 F150
50
Aug 3, 2014 07:34 PM
Schickel
May 5, 2013 06:34 PM
rockcrawler_101
Oct 5, 2012 11:03 PM
dans 51 f2
Mar 17, 2010 03:44 PM
