General Automotive Discussion
03 Chevy Malibu - I know it's not a Ford...
Old Nov 25, 2012 | 02:30 PM
Trail_Rider's Avatar
Trail_Rider
03 Chev Malibu. Full of fuel, but gauge reads empty (it works) fuel pump runs to pressure when key is turned on, car starts and runs about 5 secomds then dies, with key still on pump comes on again and car will start again and run about 5 seconds then die again. Car was driven yesterday with no problems. Just started this today. Fuses seem fine. Cannot locate emergency fuel pump shut off - if it has one. Pump was changed about 2 years ago, which means absolutely nothing other than it is pumping enough to get it started. It runs just fine once it has started with ether sprayed into the intake. Anybody got any ideas?
Thanks
Old Nov 25, 2012 | 02:31 PM
fmc400's Avatar
fmc400
MSEE
This needs to go in the General Automotive Discussion forum: General Automotive Discussion - Ford Truck Enthusiasts Forums
Old Nov 25, 2012 | 03:20 PM
davewild's Avatar
davewild
is there a security light on? Sounds like a security issue to me, any problems with the key or ignition switch lately?
Old Nov 25, 2012 | 03:33 PM
turbohunter's Avatar
turbohunter
I have no words
Old Nov 25, 2012 | 03:34 PM
wyckedcombo17's Avatar
wyckedcombo17
Is it getting a valid CKP signal? Do you have a scope?
Old Nov 25, 2012 | 03:38 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
And so it has
Old Nov 25, 2012 | 03:40 PM
turbohunter
Nice to see/read ya over here Steve.
Old Nov 25, 2012 | 07:53 PM
Phinxter's Avatar
Phinxter
do you have a security light on/flashing either while in run or running? If the PCM doesn't get a valid fuel enable signal it will start then cut the fuel off like you stated, which is a theft deterrent feature. This could be a problem with the igntion switch, BCM, PCM or wires. If you have access to a scan tool a DTC might be set in the PCM for fuel enable signal invalid.
About a month ago I had turd of a Grand Am (N body same as Malibu) with the same problem after a guy did an engine swap. I found a rodent nest in the HVAC blower and near that was the BCM it had used for it's toilet. The BCM had to be replaced along with most of the wires going to it, but after that it fired right up ran and smoked and knocked real bad. The engine he put in was junk, but I drove it out of the shop.
About the fuel gauge... I think it is a seperated issue, prolly just a bad sensor, or wiring issue.
Old Nov 30, 2012 | 06:27 PM
Trail_Rider
RE: Malibu
Thanks for all the help, still working on it, with no positive results. It does have a new fuel pump in it though. OUCH!!!
sparks717
Nov 25, 2023 09:59 AM
xfrog
Dec 3, 2014 07:56 PM
drad
19
Jan 17, 2013 12:27 PM
jargabright
Dec 31, 2012 06:43 PM
99f250craig
Jun 30, 2011 10:46 PM
