Need Door Hinges for My '49
Old Nov 9, 2012 | 08:29 PM
wavetrain75's Avatar
wavetrain75
**Still looking***
Looking for stock door hinges for a '49 F-1. Need the top hinge only for both drivers' and passenger side. I need only the portion of the hinge that bolts to the cab of the truck, the doors do still have the other half attached. I do not need the triangle piece that the hinge bolts into on the cab.
Thanks
Old Nov 9, 2012 | 09:58 PM
aussiecowboy's Avatar
aussiecowboy
Assuming because of wear? Most that you'll find will be every bit as worn. I looked for ages and eventually reamed out the hole and bushed it with a bronze bush, then reamed the bronze to the size of the hinge pin. Wasn't hard or expensive and the doors are now like new.
Old Nov 9, 2012 | 10:06 PM
wavetrain75
Originally Posted by aussiecowboy
Assuming because of wear? ...
Nope, removed and now missing.
Old Nov 9, 2012 | 10:12 PM
tinman52's Avatar
tinman52
Welder User
I may have some, will take a look tomorrow.....
Old Nov 9, 2012 | 11:01 PM
aussiecowboy
That's different then, hard to bush thin air
Old Nov 10, 2012 | 01:02 AM
51PanelMan's Avatar
51PanelMan
I have a pair of doors that are junk, but the hinges are good. If Scott can't find his, I can cut and remove the ones from my doors.
Old Nov 10, 2012 | 08:36 AM
wavetrain75
Thanks, guys, please let me know what you come up with.
Old Nov 10, 2012 | 06:16 PM
F1 48 Ford's Avatar
F1 48 Ford
I have a 50 junk cab with doors that will be going to the crusher.Let me know if you need them.
Dean
Old Nov 10, 2012 | 07:12 PM
wavetrain75
Dean
I sure do, shoot me a price for the top hinges.
Old Nov 10, 2012 | 11:05 PM
tinman52's Avatar
tinman52
Welder User
I don't have any that are easy to get off......sounds like you got some other offers anyway.
Old Nov 23, 2012 | 06:53 PM
wavetrain75
Still looking, if anyone has some give me a shout!
Old Nov 26, 2012 | 09:45 PM
51PanelMan's Avatar
51PanelMan
Do you need just the plate portion of the hinge that is pinned to the internal hinge on the door and is then bolted to the hinge pillar or do you need the complete hinge assembly including the hinge welded to the door?
I have two doors that can be parted for the hinges.
Old Dec 1, 2012 | 08:16 PM
wavetrain75
Yeah my description wasn't the best. I need the portion of the hinge that bolts to the cab of the truck, the doors do still have the other half attached.
Old Jan 9, 2013 | 09:06 PM
jpmanyhearts's Avatar
jpmanyhearts
hey guys sorry to be getting off track but I made a huge mistake and cut my hinges off my 51 f-1 thinking I could get new ones but at this point I would have better luck finding gold chicken teeth I tried for 3 days to get the pin out so I thought I'll just cut them off and order new ones aaahhhhh research then cut like measure twice cut once.............................................. .......................so does any one know where I could get a set of door hinges for a 52 f-1 ???
Old Jan 9, 2013 | 09:23 PM
51PanelMan's Avatar
51PanelMan
I have a set of four still attached to some junk doors. PM sent.
bakerbuilttracks
Jul 4, 2019 07:27 AM
nikmish
20
Dec 3, 2014 07:21 AM
emgee
Jun 29, 2011 01:26 PM
CraigK
Mar 2, 2009 07:36 PM
needhelp49
Oct 16, 2007 11:39 AM
