Rear hatch door lock actuators?
Old Oct 18, 2012 | 12:34 PM
BroncoRN's Avatar
BroncoRN
How do you get to them? Is there one or two actuators? Can you use right side or left side to replace it/them?
Old Oct 18, 2012 | 01:27 PM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
You have to take the rear hatch panel off. Easiest if you open all the doors in the back, sit down in the truck and pull the hatch down. Take the handle off, pull panel and dust shield. There will be only one actuator in there and I believe it's the driver side that you will need. I will double check on this unless someone else chimes in. The actuator itself is sitting behind a little plate on the door, it's not too hard to get to. Just take your time getting it out so you don't break any of the little plastic pieces.
Old Oct 18, 2012 | 01:34 PM
Turfzilla's Avatar
Turfzilla
Search for crazy001. He had a nice write up. You likely can just repair yours!!
edit: write-up
Old Oct 18, 2012 | 11:58 PM
VQT's Avatar
VQT
I sprayed mine with grease and work the key until the actuator losen up, the power lock work for the last 8-9 months now. Own the Ex for ~11 months.
there are other post about greasing and work the key until it free up. Search for it!
https://www.ford-trucks.com/forums/2...lock+actuators
https://www.ford-trucks.com/forums/9...-actuator.html
Good Luck
Old Oct 19, 2012 | 12:00 AM
VQT's Avatar
VQT
Foound the post
https://www.ford-trucks.com/forums/1...tch-locks.html
f150homie
1997 - 2003 F150
Oct 12, 2012 08:08 AM
hotbrass
Apr 16, 2011 10:05 PM
Hunt4Fun
Aug 17, 2008 10:26 AM
austinjorg
Sep 21, 2006 03:23 PM
CT Cruiser
Jul 19, 2006 03:11 PM
