Door lock
Old Jul 12, 2006 | 12:20 AM
CT Cruiser's Avatar
CT Cruiser
Door lock
I was wondering if there is a trick to getting the door lock to work. Or if it is common for them to go out after some time. When I push down on the door lock it only moves down half way and then pops back up as soon as I take my finger off of it. When I try to use the key it won't budge. I tried tinkering with it but no luck. I don't want to take the other door apart to see how that works if I don't have to.
Old Jul 12, 2006 | 06:41 AM
jowilker's Avatar
jowilker
CT, The locks are pretty simple, you will have to access it through the inner door panel. Go armed with a can of WD40 and spray everything real good. Until you get in there and diagnose it, it is a little hard to call, except it should be simple to fix.
John
Old Jul 13, 2006 | 06:13 PM
Nod's Avatar
Nod
Door Locks
CT Cruiser,the lock on my 72 is so bad that it always drops down to the locked position no matter if I pull it up it falls right back down,I have accidentaly locked myself out already but cannot figure out why it is doing this.Before this the lock was acting as yours is,I tried lube but it seemed to make it drop down easier.I am going to have to take off the inside panel again and try to remove the whole lock to see what is broken.Let me know if you find anything and I will do the same.
"bowties in the rearview mirror"
Old Jul 15, 2006 | 10:00 AM
DarkWolf40's Avatar
DarkWolf40
I converted mine to power locks and now don't have to worry about it. Just push a button and everything locks or unlocks.
Old Jul 18, 2006 | 11:55 PM
CT Cruiser's Avatar
CT Cruiser
I took the other door apart and discovered that there is a little spring the pushes the lever back up against the outer door mechanism. When it is pressed up against the outer mechanism there is a slot on the lever that allows the lock to make clearance. I found the old spring laying at the bottom of the door so I was in luck.
Old Jul 19, 2006 | 06:49 AM
jowilker's Avatar
jowilker
CT, Thanks for the report. I had an idea it would be simple.
John
Old Jul 19, 2006 | 10:59 AM
Mil1ion's Avatar
Mil1ion
Cleaning and re-lubing has always made these door locks worse.
I think the key is the type of lube to use.
Old Jul 19, 2006 | 11:11 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Lock-Ease" a graphite base product suspended in a petroleum distillate, penetrates into the lock / key slot then the solvent evaporates leaving a dry film. No oils to collect dust and dirt.
.....=o&o>.....
Old Jul 19, 2006 | 12:58 PM
Mil1ion's Avatar
Mil1ion
I'm talking about lube for the locking mechanism inside the door to hold the lock button UP..
It looks like Floor wax in consistency.
Old Jul 19, 2006 | 03:11 PM
hotrodfordpickup's Avatar
hotrodfordpickup
LOVE my ford door locks..no matter how jacked up you are the key goes in eather way and its pointed to center it self..and as a bonus it slides right into the ignition..I might not find my way home but i can always start my trusty old ford truck...lol hope this strikes your funny bone....bill
