Taking truck to dealer Friday - service
While its there I am going to have them look at a few things:
1. Back up sensors - they work intermittently with a message that comes up saying "check back up sensors" or something to that affect on the display. The icon on the display that lets you check off or on will not let you put a check mark next to "on" after you push the "OK" button to get out of the check message. There is nothing coating the bumper/sensors (mud or anything).
2. Blinkers - sometimes, out of the blue, my left turn signal comes on and it doesn't like to go off. I have to push the blinker wand down to the second full position then back, or repeat if it comes back on. It is almost always the left blinker. It also happens sometimes when I start the truck.
3. Windshield wipers - sometimes if I go from the remote start to key power in the morning I get the windshield wipers going. So I will turn them on with the dial and back off. This is pretty rare.
4. The Ford emblems are starting to corrode.
5. I might have them look at the cruse control - sometimes I can get the light to come on the dash and go to green when I push the + button, but it doesn't hold the speed. I have to shut the truck off and restart all the electronics for it to start working again.
Do any of you know how to check the back up sensors?
My gut tells me with the rest of the issues that unless they can repeat and verify my "complaints" they won't be able to do anything. There probably isn't a code thrown for the blinkers going on at will. Any thoughts? Is there anything I might be able to do to fix it? Or do these issues require parts being replaced - which we're back to square 1 with being able to verify what it's doing at the dealer?
I get a similar problem with the easy entry/exit seat setting where sometime it wont work, and you go into the menus and you cannot check the box to turn it off or on. Stays that way until a restart of the truck. Again, reported to Ford, even with a video showing it, but since they couldnt reproduce the problem themselves, no fix. Only has happened twice in almost 2 years.
These minor issues can add up in a hurry. I had the electric seats repair on another truck and it was almost $1k. The dealership told me that the evaporator replacement they did on my SD under warranty would have been $1800.
These trucks are packed with electronics!
That having been said, none of the other issues they could replicate so no fix yet. I did spend some time with the tech working on it and figured on when it starts acting up again I'll take it back in. He did mention in the diagnostics that the hotline recommended was to unplug a module to see if that makes the blinkers or the wipers quit. I don't know how everything integrates with each other, other than the blinkers and the wipers are on the same wand.
Another note regarding the transmission fluid flush - they still recommend changing it at 30k - especially the 6 speed torq-shift transmissions. Does anyone have any possible documentation as to why this would be recommended? Even the heavy-service/severe service schedule doesn't spec 30k? Was there ever a service bulletin that came out regarding this? The writer did mention that ford has a zero-tollerance policy regarding scheduled maintenance along the same conversation topic.
