Has anyone had to deal with a dead Electronic Climate Control unit?
Mime will work some time and then be dead. I don't happen to
have a wiring diagram for it.
Do these units fail do to poor solder joints like the FICM?
I have no problem pulling it out and re-soldering.
In this photo it is working again. With a little bit
of time it will go dark again
So I am not crazy, some one else has had this happen also. Mine has died about 4 times since truck was new and have never found the cause. I have just shut truck off then restarted and it's worked every time, it's never died while driving ,just on start up. I would love to hear if there's a reason for it or just electronic hiccup.
Try cycling your headlight switch the next time it goes dark.
As stated above. Try cycling the headlight switch. That usually works. Bottom line the head unit is starting to fail. How long you can nurse it is an unknown.
BLADE35
Speaking of tear into it.
I did have a look inside mint today.
What a crappy soldering job I see lots of cold
flow joints (solder had started to cool) with dull and bubbly finishes
Unit was made in your guess it Mexico. Nothing really jumped out at saying I'm bad I am going to try to get my hands on a replacement before I
put this one on the bench and take the chance of killing it for good. If some one has an electronic schematics for this unit I could really use a copy. Working on some thing blind really sucks.
For the most part the unit is all surface mount components and a few ICs
Part of the reason I had the dash put was to re-lamp the instrument panel.
Did you know when you unplug the instrument panel the over head lights
go out along with the door open key in chime
That makes sense^^^^ since the wire harness would be disconnected and the circut Open
Originally Posted by Yahiko
BTW that headlight trick works well.
Wonder what changes when the Headlight turned on
Wonder if its cuz the Headlights being on also illuminates Dash and the Climate control display must go from Dim to Bright
