Edge Juice Platinum Problems
Old Jun 6, 2012 | 08:36 PM
jonathonjeremiah's Avatar
jonathonjeremiah
Hey guys,
I havent posted in a while. I have found many soulutions to my questions/ problems on this site. I am hopin that you can help me with one more.
I have a 2006 F350 crew with the 6.0 and the six speed manual.
I recently acquired an Edge Juice Platinum with Attitude. I bought it off of e-Bay, where the seller stated that there was nothing wrong with it and he had only had it for one month. I got it in the mail today and it looks great, dosent even look like it had been installed. The only thing that was missing was the adapter to thread in the egt probe. The egt probe looks as though it had never been used. I installed it this afternoon with no trouble. Started the truck and it ran fine. The attitude was showing me all of the informaion(except the egt, since the probe was not installed). I took the truck for a test drive and there was no change from stock, on any of the settings. I checked codes on the thruck and there were none, I then checked codes on the juice and came up with 3 P0002, P0003, P0008. P0008 says that it is low voltage on the egt wich makes sence since it is not hooked up. The operators manual says that it will run correctly with out the egt probe hooked up, Edges website says the same. P0002 and P0003 have to do with can a and b, and I am assuming that this is my problem. Does anybody know how to track this down, or knows where I can find a wiring diagram. I have removed all of my connections to check for bent pins and I found none. I unhooked the batteries for over 15 min and the codes are still there. I tried to call edge but unfortunatly it is after there operating hours, So I thought I'd try here first. I just want to find out if there is a problem with my truck or the edge, so I can return it asap to the seller on ebay.
Thanks guys!
Old Jun 6, 2012 | 10:59 PM
KRDiesel's Avatar
KRDiesel
p0002 AND p0003 are not in the PC-ED. I think you may have ghost codes. If you have a newer strategy that the edge does not know about you will get strange things.
Call them , I do not know if you can update it through the internet or if you have to send it to them.
BTW do a search on this forum about the Juice, They love to kill tranies.
Old Jun 6, 2012 | 11:26 PM
jonathonjeremiah
Thanks, I will call them tommorow.
BTW do a search on this forum about the Juice, They love to kill tranies.[/quote]--How do they kill manual tranies? The clutch maybe? is that what you ment?
Old Jun 6, 2012 | 11:29 PM
KRDiesel's Avatar
KRDiesel
oops on my part. I did not catch the manual part. it is the auto that they will kill.
ChunderDownUnder
Jul 7, 2009 10:59 AM
Vinford
Computer Chips & Tuners
Dec 21, 2008 08:59 PM
GEugeneS
Jun 5, 2007 09:46 PM
mbogosia
2004 - 2008 F150
Apr 15, 2007 06:21 PM
Brian429
2004 - 2008 F150
Mar 18, 2007 08:23 PM
