1947 1 ton - 4 speed shifting
Old Jun 1, 2012 | 12:10 AM
PeeVee's Avatar
PeeVee
I've just started driving my truck after putting it together over a period of over 10 years! It's all stock. The g/box was checked out and everything looked fine. But I have difficulty finding third gear, especially when gearing down. It's not so much matching the revs but actually finding the slot where I can engage the gear to avoid the crunch. There seems to be about a 2 in. spread on where I can put the gear lever. I suspect wear in the selector fork assembly. But then, maybe this is just the nature of the beast?
Feedback or comments appreciated.
Thanks
Peter
Old Jun 1, 2012 | 07:57 AM
newold46's Avatar
newold46
These are straight cut gears and will grind almost no matter what you do. Try double-clutching and see if that helps.
Old Jun 1, 2012 | 08:10 AM
loholland's Avatar
loholland
Its like newold46 said, plus you should as you down shift, rev the engine to match the speed of the truck to ease the gearing together. I remember (because I'm old) driving these old trucks and having to do this, Its an art to learn, and after you do, it will be easy.
Old Jun 1, 2012 | 10:22 AM
PeeVee's Avatar
PeeVee
4 speed shifting
Thanks all for the comments. Yes, I have to double clutch to match revs. when shifting. If I'm lucky, and hit the gate right, the change is very smooth. The problem is hitting the gate accurately. I seem to lose any reference or sense of correct gear lever position when I move the lever through neutral.
Maybe it just takes more practice.
Old Jun 2, 2012 | 02:07 AM
Steve Christensen's Avatar
Steve Christensen
Hey mate, the dowel that locates the ball on the bottom of the gear lever on my 4 speed crash box was very worn, making the lever try to turn rather than just go fore and aft.... I thought one dowel didn't seem adequate, so I drilled the gear lever tower and fitted a second directly opposite..... all good. very positive feeling.
Unscrew the retainer that holds the lever in tower and have a look for wear.
Steve.
Old Jun 2, 2012 | 03:23 PM
PeeVee's Avatar
PeeVee
4 speed shifting
Thanks Steve. That just might be the answer. Great suggestion!
Many thanks
Peter
Todd Wenke
15
Jun 16, 2022 12:12 PM
PEZLO
17
Aug 3, 2020 02:34 PM
CentralMassLandscape
Oct 23, 2008 10:49 AM
royzell
Jul 28, 2008 01:21 AM
gearhead351
Dec 31, 2005 02:18 AM
