1950 F1 transmission 4 speed
I just purchased a 1950 F1 on eBay. Only saw pictures and previous owner said its a runner. Received delivery and the darn trans is a mess! My 49 F1 with a 3 speed shifts great as long as I double clutch. The 50 with 4 speed is tough to get past 2nd gear. 3rd grinds bad and its hard to miss hitting 1st again. 4th is almost impossible to find, grinds like its got gravel rather than gear lube, it grinds so bad I cannot tell if I am hitting reverse or 4th. Once I find 4th it feels like its a bit taller than the three speed.
Any ideas on why I cannot find the shift gates? Broken ... ?
Is high gear a different ratio in the 3 speed and the 4 speed?
Thanks for help.
Todd
Thanks for help.
Todd
Yes the shift lever is very sloppy while in gear. If I pull the top off what should I look for?
Is there any cool factor or rarity that would be reason enough to keep the 4 speed and not throw a 3 speed in its place?
Why does the 4 speed exist if none of the gears were synchronized?
Thanks
Todd
Thanks
Todd
Thanks
Todd
Thanks
Todd
With the cover off, look for broken or badly worn teeth on the gears. You also want to drain the oil from the trans. and examine it for metal particles and shavings.
There certainly isn't any "Wow" factor with the four-speed, more like a loud groan. They are not rare, and most folks try to get rid of them as they are a pain to drive with. Great trannys if you like exercising your left leg and right arm, and feel you need more to do than just drive the truck.
The four speed transmission was employed mostly for use in the larger trucks, all the way up to the F4 or 5 (I think). It was standard fare for the F2 and F3, but an option for the F1. A heavy duty unit, they worked well in trucks that were, well, worked.
Start by looking at the condition of the parts that Mark described. The 4 speed was usually found on the F2/3s where stump pulling gearing was needed for starting out. Cool factors are a matter of individual taste. Replacing a 4 speed with a 3 speed would require changing the drive shaft and cross member cradle, I believe.
Why do ticks exist?
Seriously, in the day these transmissions were made, most folks preferred simplicity and durability over ease of operation. The four-speed was an easy and inexpensive transmission to produce, and was certainly durable. Most men of that era were quite proficient at double-clutching, and wanted something simple if things went wrong with the unit. There were fewer parts that could fail (no synchronizers), and the gears were no doubt cheaper to replace, as they were straight cut types, and not spiral.
I learned how to drive truck on a '32 BB. I believe it had almost the identical transmission as the one in my '52. The "whine" of those straight cut gears are like music to me - even with some grinding here and there on the shifts! If you use an F1 as a truck and haul loads with it, the 4-speed's gearing in reverse and 1st is very useful. - Bob
You need to double clutch the non-syncro 4 speeds. That means you actively shift it in to neutral (and let the clutch out) between gear changes. These also required RPM matching (especially on downshifting), so a blip of the throttle before shifting down out of neutral can accomplish that. Never try to down shift into first while the truck is in motion, only to second. It will take some practice, but quickly becomes second nature.
