3rd Gear Strugles
Old Apr 13, 2017 | 11:01 PM
PEZLO's Avatar
PEZLO
3rd Gear Strugles
My 4 speed spur gear trans won't smoothly let me get to 3rd, all the other gears are not a problem (typically). The best I've been able to do is when I double clutch to 3rd around 15 mph, I ever so slightly start into third, when I'm sure I'm barely in I have to really lean on the shifter all the way to the right as I shift up. Even with this technique I usually get a bit of a grind at best. I flipped my worn T shaped shift pin which tightened up a lot of slack but 3rd is still a small grind at best.
Thanks in advance!
Paul
Old Apr 14, 2017 | 09:08 AM
52 USCG Panel's Avatar
52 USCG Panel
I'd say 15 mph sounds a little fast for the shift to 3rd. I have a 4 speed like yours, and I usually start in 2nd and make the shift to 3rd at under 10 mph. If you limit engine speed and slowly ease the transmission into the next gear, you don't have to double clutch. I up shift as soon as possible without "lugging" the engine. Down shifting--that's another story. I need to double clutch and often there's still some grinding involved. Good luck.
Old Apr 14, 2017 | 11:06 AM
bhalemail's Avatar
bhalemail
Yep, been there on that and i agree 100%. The issue i had was down shifting and i never really could get the hang of it. With all the hills and mountains around here it became quite a struggle so i found a T87D HD 3sp (sync'd) and life is better now
Old Apr 14, 2017 | 11:08 AM
PEZLO's Avatar
PEZLO
It was a long day, as you can tell by the misspelling in my title. Your actually correct, it is closer to 10 MPH when I attempt the shift to 3rd. I'll try shifting even sooner to see where that gets me.
Thanks!
Old Apr 14, 2017 | 11:48 AM
petemcl's Avatar
petemcl
Of course your first instinct is to blame your own ability to double clutch properly. But there can be other things that contribute to the problem.
  1. Ford says to use straight 140W lube not multi-viscosity lube like 85-140W.
  2. If your engine has not run for years to may have a rough pilot bearing in the back of the crankshaft. It will need to be replaced.
  3. Of course clutch adjustment can contribute also. Easily checked by making sure that there is about 1" of movement of the pedal from the top before the clutch starts to be engaged.
Old Apr 14, 2017 | 12:02 PM
PEZLO's Avatar
PEZLO
Thanks Pete,
I just changed the transmission oil and was talked out of using 140w for 90w gear oil. They "old car guy" said if I was having shifting problems it would only be more difficult with 140w. Was this a mistake on my part, should I have stuck with the 140w?
Paul
Old Apr 14, 2017 | 12:51 PM
petemcl's Avatar
petemcl
Originally Posted by PEZLO
Thanks Pete,
Paul
That might (?) be true on syncro transmissions but on non-synchro transmissions you want to slow the gears down quickly when you double clutch so you can match input and output gears. 90W has less resistance than 140W. I have always just gone by what Ford recommends.
The T9 is a beast anyway you work it and will never shift like a Muncie . . . But it is very strong.
Old Apr 14, 2017 | 01:15 PM
JPMallory's Avatar
JPMallory
I'm running 85W-140 in my crashbox, and your above statement would probably explain why my shifts grind a little until the truck warms up.
Old Apr 14, 2017 | 01:32 PM
cowdog86's Avatar
cowdog86
Try turning the idle screw up a bit. 50 to 75 rpm. Then try it. Or you can just give it a freckle more throttle with the footfeed. My 51 idles so low I didn't have enough revs on the input. After I did that, I can shift it like old grampa. I turned my idle up a hair just because I am lazy
Old Apr 16, 2017 | 09:30 AM
PEZLO's Avatar
PEZLO
I'll give those a try and see if I can smooth things out a bit.
Thanks all!
Old Apr 16, 2017 | 01:12 PM
3twinridges's Avatar
3twinridges
When I purchased my truck several years ago it shifted fine but I had no idea how old the gear oil was. I used I think sta lube 90 from o'reileys. Shifting become more of a challenge with grinds into 2nd and into 3rd. I drained it and put in sta lube 140. Shifted perfectly. This was on a 3 speed column shift.
JB
Old Aug 2, 2020 | 02:29 PM
Fathumb's Avatar
Fathumb
sorry miss post
Old Aug 2, 2020 | 08:33 PM
Latchman44's Avatar
Latchman44
3rd Gear
I have the exact same issues shifting into third gear and I agree with shifting around 10-mph. Some times I'm in fourth by 15-mph.
I can go around the corner with the clutch in and let it out in fourth on the other side without lugging the motor. No down shifting. 4:86 gears!!
Sometimes a faster idle is no bueno. If I have the choke out, it raises the idle and makes it harder to shift into third. My experience anyway.
I have all new clutch components and I still have to be careful going into third. May truck is a 1951 M3 with the T9.
Down shifting from fourth to third is possible, but from third to second, forget it.
Shift slowly at a low RPM. Can't be in a hurry driving these things.
Old Aug 3, 2020 | 05:46 AM
fordf348's Avatar
fordf348
I have the same shifting issues with my truck and I learned to drive it 58 years ago, my father bought it new and always complained about how difficult it was to shift. I keep mine original and find that the shifting problems are what makes it an old truck
Ed
near Philadelphia
Old Aug 3, 2020 | 06:17 AM
52 USCG Panel
My brother and I learned how to drive on my truck too. My dad never taught us to double clutch. We just kept engine revolutions down for up shifting and tapped the accelerator a little with the clutch in for down shifting around corners. Shifting slow and easy is key. I usually double clutch now, but still do some grinding--it's a sound associated with an authentic old truck and a part of the driving experience. Old trucks rattle and whine, and occasionally the gears grind.
Jim
