Difficult to down shift when engine braking
Old Dec 31, 2005 | 01:40 AM
gearhead351's Avatar
gearhead351
Question Difficult to down shift when engine braking
I have a 1984 FORD F250 with 4 wheel drive.The motor is a 351 Windsor V-8, I have one of the 2 transmissions (both manual 4 speed) its either a Warner T-18-4 or a Warner T-19-4. When I am driving in 3rd gear and try to downshift to second gear it doesnt go right into gear you have to really pull it to get it into 2nd gear or slow down to 15mph to get it in smoothly. I dont have this problem in any other gears just 3rd to second when moving. The trans fluid has been just changed. Any ideas appreciated!!!
Old Dec 31, 2005 | 02:01 AM
bob arrington's Avatar
bob arrington
match you engine speed to your road speed , bob
Old Dec 31, 2005 | 02:03 AM
bob arrington
or, if you've never driven a 'big' truck , give it a little gas as you attempt to slide it in the lower gear ,bob
Old Dec 31, 2005 | 02:18 AM
gearhead351
yes I have driven a big truck. Its almost like somthing is stopping the gear change.
