Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F-800 questions???
Old Mar 21, 2012 | 08:39 AM
CTPATRIOT's Avatar
CTPATRIOT
F-800 questions???
I'm looking for a s/a dump truck.I have Mack's and other old trucks,but have seen some good deals on 1980's Fords.Most seem to have 429's in them.How's the reliablility of them,also what type of MPG's with a 5/2 speed rear setup?
Old Mar 22, 2012 | 09:47 AM
Mr. Mcbeevee's Avatar
Mr. Mcbeevee
I cannot tell you much about the reliability yet, but I have a 1991 F-800 with 429 5 plus 2 speed set up that is getting a dump bed put on it. From what I have talked to people these trucks get from 6-8 mpg hauling 10 ton of rock. This is hauling from a quarry that has 4 different 8% grades to go over if this helps. I can give you some exact numbers when I get my truck back in a couple of weeks.
Old Mar 22, 2012 | 12:31 PM
CTPATRIOT's Avatar
CTPATRIOT
Thanks very much for the info!Deff. would like the numbers when you get them.Doesn't seem much more worse than a BB pickup!
Old Mar 22, 2012 | 02:25 PM
cj06's Avatar
cj06
we had an F700 with that engine in it and a big ole utility box on the back with 1000 gallons of water tanks and pulled our drilling rig , truck and trailer weighed close to 40,000 pounds loaded ! it pulled OK in town on flat land wernt worth a hoot pulling up hills ! it got around 4-5 MPG loaded !
now with the high cost of gas I would look for a diesel and stay away from any gas engine in a medium truck !
the durability seemed good with maintenance !
Old Mar 23, 2012 | 12:58 AM
rummur s.c.'s Avatar
rummur s.c.
i had a 700 with that 429, and that thing got 4-5 mpg loaded or unloaded. I was not impressed. Washington's not known for flat terrain though.
Pretty tough engines though. Easy 100K. Cheap to rebuild. Good for beginner drivers because the engine isnt powerful enough to break any thing..
Old Mar 30, 2012 | 07:19 AM
Mr. Mcbeevee
Just hauled 9.35 ton of rock 125 miles round trip. Gross weight was 32200 lbs. It took 24.3 gallons of gas for an average of just over 5mpg.
Old Mar 31, 2012 | 12:39 AM
rummur s.c.
9.35 ton on a 700 truck.. WOW. That truck was heavy. I remember driving mine at 24-25K and it seemed like the limit.. 4 more ton would be nuts.. Must be pretty flat terrain?
add:
Ahh - F800, and 91, with fuel injection.. Must help the MPG's
Old Apr 2, 2012 | 07:18 AM
Mr. Mcbeevee
4bbl carb, not very flat terrain.
Old Apr 3, 2012 | 01:57 AM
rummur s.c.
Hmm, thought 90 was the last year they used carburetors.. Maybe not? Either way, 5mpgs at that weights isnt too bad..
Roundgunner
18
Feb 5, 2015 06:31 PM
wagonerkl
Bronco II
22
Mar 6, 2009 05:19 PM
TucsonTripleB
Feb 9, 2007 01:25 PM
stebab
Jan 10, 2007 08:53 AM
martin350
Oct 4, 2005 04:09 PM
