F-800 questions???
I cannot tell you much about the reliability yet, but I have a 1991 F-800 with 429 5 plus 2 speed set up that is getting a dump bed put on it. From what I have talked to people these trucks get from 6-8 mpg hauling 10 ton of rock. This is hauling from a quarry that has 4 different 8% grades to go over if this helps. I can give you some exact numbers when I get my truck back in a couple of weeks.
we had an F700 with that engine in it and a big ole utility box on the back with 1000 gallons of water tanks and pulled our drilling rig , truck and trailer weighed close to 40,000 pounds loaded ! it pulled OK in town on flat land wernt worth a hoot pulling up hills ! it got around 4-5 MPG loaded !
now with the high cost of gas I would look for a diesel and stay away from any gas engine in a medium truck !
the durability seemed good with maintenance !
9.35 ton on a 700 truck.. WOW. That truck was heavy. I remember driving mine at 24-25K and it seemed like the limit.. 4 more ton would be nuts.. Must be pretty flat terrain?
add:
Ahh - F800, and 91, with fuel injection.. Must help the MPG's
add:
TucsonTripleB
02-09-2007 01:25 PM
martin350
10-04-2005 04:09 PM
