Can anyone tell me where I could locate the 2 rubber filler hoses that run from the gas tank to the metal filler pipe? I have tried several of the on-line vendors with no luck. I bought the ones from LMC Truck for the F100 but they are about 2 inches short.
I bought the ones from LMC Truck for the F100 but they are about 2 inches short. That was your first mistake because LMC has no clue. Let's hope you don't make another, by buying more wrong hoses.
I assume this is a Styleside.
Describe the two gas tanks and where they are located, that you want the 2 neoprene rubber filler hoses for.
Applications: 1967 F100/250 Stylesides / No Ford Dealer or obsolete parts vendor has any.
1968/69 F100/250 Styleside is different (C8TZ-9047-F replaced C8TZ-9047-D). No one has either of these hoses.
1970/72: The hose is different again...because the fuel cap pokes thru the quarter panel below the scallop line in front of the left rear wheel.
1973/79 mid-ship & aft axle tanks have the filler tube/cap in approx the same location as 1970/72.
1975/79 F100/350 Styleside "mid-ship" tank hose (D5TZ-9047-D) has been repro'd by Carpenter and is the one all the repro parts sellers have.
I have Carpenters 1967/79 truck repro parts catalog (2011 paper version): The only hose DC has for the mid-ship tank is D5TZ-9047-D. There are no filler hoses listed for any 1967/74's.
Give this a shot. Go to your local carquest, yes it must be car quest because autozone, advance auto, and o'reilly's are all ignorant on this. Find out the diameter of the hose that you need go in and tell them that you are looking for a fuel filler hose or whatever its called. they sell it by the foot and i think when i bought it two years ago it was like $12.50 or something. Anyways they should have that size in stock. They are the only place that i found that at, and if they have a guy that at least knows how to rebuild a carb, instead of trying to convince you to buy one, he should be able to help.
