1967 F250 Gas Tank Rubber Filler Hoses
Can anyone tell me where I could locate the 2 rubber filler hoses that run from the gas tank to the metal filler pipe? I have tried several of the on-line vendors with no luck. I bought the ones from LMC Truck for the F100 but they are about 2 inches short.
Thank you very much for the assistance.
That was your first mistake because LMC has no clue. Let's hope you don't make another, by buying more wrong hoses.
Describe the two gas tanks and where they are located, that you want the 2 neoprene rubber filler hoses for.
Thank you very much for the reply NumberDummy....you are definitely appreciated.
This is a 1967 F250 Camper Special with one gas tank.
The larger hose has a 90 degree bend and is approximately 18" - 19" with approx. a 2 1/4" inside diameter
The smaller (vent line) hose is a straight hose approximately 17" - 18" with approx. a 7/8" inside diameter
My mechanic is proposing using these short hoses and splicing the ends with a metal peice and clamping to get them to length.
Thanks again!
Thanks again!
1967/69: The exposed fuel cap pokes thru the quarter panel (bedside) above the scallop (bumpside) line, in front of the left rear wheel.
Inside the bed, butted up against it is a shield that protects the fuel filler tube from possible cargo damage.
If this tank description matches the tank you have:
C7TZ-9047-B .. Fuel Filler Hose-includes vent hose / Obsolete
Applications: 1967 F100/250 Stylesides / No Ford Dealer or obsolete parts vendor has any.
1968/69 F100/250 Styleside is different (C8TZ-9047-F replaced C8TZ-9047-D). No one has either of these hoses.
1970/72: The hose is different again...because the fuel cap pokes thru the quarter panel below the scallop line in front of the left rear wheel.
1973/79 mid-ship & aft axle tanks have the filler tube/cap in approx the same location as 1970/72.
1975/79 F100/350 Styleside "mid-ship" tank hose (D5TZ-9047-D) has been repro'd by Carpenter and is the one all the repro parts sellers have.
I have Carpenters 1967/79 truck repro parts catalog (2011 paper version): The only hose DC has for the mid-ship tank is D5TZ-9047-D. There are no filler hoses listed for any 1967/74's.
Give this a shot. Go to your local carquest, yes it must be car quest because autozone, advance auto, and o'reilly's are all ignorant on this. Find out the diameter of the hose that you need go in and tell them that you are looking for a fuel filler hose or whatever its called. they sell it by the foot and i think when i bought it two years ago it was like $12.50 or something. Anyways they should have that size in stock. They are the only place that i found that at, and if they have a guy that at least knows how to rebuild a carb, instead of trying to convince you to buy one, he should be able to help.
Mike
Mike
hhight
03-30-2014 06:35 PM
abyars111
15
10-02-2013 12:19 PM
andydunks
06-24-2012 02:45 PM
Bookman
11-22-2004 04:30 PM
