1989 F150 351W skip/misfire
Old Feb 8, 2012 | 03:49 PM
emloera's Avatar
emloera
I recently bought a 1989 F150 with a 351W, C6, and 4x4. The truck fires up and idles like a new one. Sometimes it will try to stumble around once you put it into gear, but that is a rarity. The real problem comes in at highway speed. It will skip/misfire around 50-55mph if you try to hold speed. Under heavy acceleration it runs great with normal 351 power. I have felt the concern both when it's warm and cold, although I've noticed it more when it's warmed up. I thought a tune up would solve my problem, but to no avail. Here is a list of what I have done:
-motorcraft plugs gapped to 44
-ford racing 9mm wires
-motorcraft rotor
-new dist cap
-new fuel pressure regulator
-new 195 degree thermostat
This problem seems to be fairly common with these trucks... hopefully somebody can shed some light on it for me!
Old Feb 8, 2012 | 04:44 PM
SCRebel's Avatar
SCRebel
Could be a injector sticking. Couldn't hurt to put some lucas injector cleaner. Also does it jusr skip at a certain speed, or when your gas pedal is in a certain spot?
Old Feb 8, 2012 | 05:12 PM
emloera's Avatar
emloera
I have ran a double dose of Lucas injector cleaner through it. I think you're going towards a TPS with the gas pedal position idea, but I hope that ain't it cause those ain't cheap! It seems like it does it worst if you're trying to hold your speed with the trans in high gear (3Rd) without it shifting down into second.
Old Feb 8, 2012 | 06:58 PM
SCRebel's Avatar
SCRebel
Throttle position sensor are about $35. Not too bad, but aggravating to replace. If you have to original TPS it wouldn't hurt to replace.
Also, is the fire coming from the coil nice and strong?
Old Feb 9, 2012 | 06:28 PM
emloera's Avatar
emloera
I replaced the coil tonight after work, made no difference...
Old Feb 10, 2012 | 11:57 AM
rla2005's Avatar
rla2005
I did not realize you had two different posts for the same issue. My answer is here: https://www.ford-trucks.com/forums/1...p-misfire.html
Old Feb 10, 2012 | 03:45 PM
SCRebel's Avatar
SCRebel
I believe there are 3 threads.
Old Sep 11, 2018 | 04:06 PM
Nicholas Smith's Avatar
Nicholas Smith
magnumcccc
73
Apr 15, 2026 08:15 AM
doo71dene
Aug 23, 2019 08:44 PM
emloera
Sep 12, 2018 11:29 PM
rdneckdeluxe
Aug 7, 2004 10:10 PM
