89 F150 351W skip/misfire
I recently bought a 1989 F150 with a 351W, C6, and 4x4. The truck fires up and idles like a new one. Sometimes it will try to stumble around once you put it into gear, but that is a rarity. The real problem comes in at highway speed. It will skip/misfire around 50-55mph if you try to hold speed. Under heavy acceleration it runs great with normal 351 power. I have felt the concern both when it's warm and cold, although I've noticed it more when it's warmed up. I thought a tune up would solve my problem, but to no avail. Here is a list of what I have done:
-motorcraft plugs gapped to 44
-ford racing 9mm wires
-motorcraft rotor
-new dist cap
-new fuel pressure regulator
-new 195 degree thermostat
This problem seems to be fairly common with these trucks... hopefully somebody can shed some light on it for me!
-motorcraft rotor
-new dist cap
Here is some light from Steve83: 1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s
Starting your own new thread would be highly suggested. Cross posting in a thread that has already morphed into multiples only results in confusion.
Based on your video and statements: No Codes. You most likely have a bad computer. And I also would expect multiple issues given your other info about the truck's history.
well i will start a new thread but i can say its not the fuel injectors or the computer because i just bought a reeman today and it made no difference i am kinda feeling cursed by this truck at this point is there any other suggestion
new thread (https://www.ford-trucks.com/forums/1...l#post18192395)
emloera
Sep 11, 2018 04:06 PM
mysticalcracker
Mar 5, 2010 11:29 AM
tegger
Aug 6, 2004 01:37 PM
jeepin
Jun 30, 2003 05:10 PM
