351W knocking problems
Old Aug 5, 2004 | 10:40 PM
rdneckdeluxe's Avatar
rdneckdeluxe
Cool 351W knocking problems
The victim is 1993 F-150 5.8L Windsor. i cannot figure out why my truck shakes like a volcanoe, everytime I hit between 35-40 mph. It only happens when I hit that speed the first time; afterwards, every other time i hit that speed it doesn't shake. I have replaced my spark plugs, wires, and distributor cap. I have used injector cleaner, and put in a new fuel filter. I took my truck to a local auto shop; they put it on the computer, and the only thing they found out is that one of my left injectors is missing. They put the injector cleaner in, and said if that doesn't work that i might have to replace the injector. Well, from what i know,if something clogged that fuel injector that much to shake the truck, something has to be up with my filter. That's why i changed it, but the truck still shakes. Any advice would be greatly appreciated. By the way, i don't think it's the tranny either.
Old Aug 5, 2004 | 10:51 PM
sty's Avatar
sty
Check your u joints. They can make the truck shake at certain rpms. My F 150 did the same thing . Do you know how to check them? ( No flame intended .) On a lighter note , you should get great gas mileage for fine tuning the motor!
Good luck!
Sty
Old Aug 5, 2004 | 10:53 PM
rdneckdeluxe
yeah
yeha i forgot to mention i did check the u-joints too. they're plenty strong. thanks though for the thought
Old Aug 6, 2004 | 08:08 AM
71swissaqua's Avatar
71swissaqua
Did you replace the one injector that was missing? Injectors are easy to change but not real cheap.
clint
Old Aug 7, 2004 | 10:10 PM
rdneckdeluxe
i'm going to try replacing it in the next couple of days. i'm still giving the fuel filter a couple of days to cycle through. Thanks for the comment.
Tugly
22
Nov 17, 2015 10:33 AM
BroncoBilt
1978 - 1996 Big Bronco
Jan 2, 2015 10:53 PM
Kweli
Modular V8 (4.6L, 5.4L)
Feb 16, 2013 11:03 AM
xshovelheadx
Oct 30, 2009 04:38 PM
wiredawg119
May 25, 2009 10:15 AM
