88 f150 302 won't start
Old Oct 9, 2011 | 12:33 PM
drallab1's Avatar
drallab1
I have a 88 f150 that quit running. It cranks over but won't start. I do not hear the fuel pump running when the key is on. Very little fuel comes out of the fuel rail when I push the needle valve down on the fuel rail. The fuel shut off switch is not tripped. Any suggestions where to start or should I drop the tank and change the fuel pump.
Old Oct 9, 2011 | 01:27 PM
brcwelding's Avatar
brcwelding
First off check to see if you are getting spark. If you are then change the fuel filter. If it still doesnt run then i would take the tank off and change the fuel pump. Just some advice, the fuel pump is a pain to do with the bed on. Make sure you have someone their to help you with it or else it is going to be a nightmare.
Old Oct 9, 2011 | 02:27 PM
Slip ford man's Avatar
Slip ford man
I think that you also have another high pressure fuel pump, located on the chassis rail, drivers side...ground #2 to#6 on the test plug which will cause the pumps to run continuous for testing.
Old Oct 9, 2011 | 04:16 PM
drallab1's Avatar
drallab1
Getting spark at the plugs, Where is the test plug located so I can ground #2 and #6?
Old Oct 9, 2011 | 04:44 PM
subford's Avatar
subford
It is located on the drivers inter fender, photo below.
If shorting 2 to 6 with the key on does not run the pumps try grounding pin #6 to the NEG (-) post of the battery.
I would do some checking before changing out the pumps.
Old Oct 9, 2011 | 06:46 PM
drallab1's Avatar
drallab1
After jumpering all that out, still didn't work. Notice a plug on negative side battery cable, not plugged in. Plugged it in and truck runs. Don't know why or how this got unplugged,( son's truck), but running now . Thanks for all the help.
Luckylady11
Feb 26, 2016 02:50 PM
stsscott
41
Apr 11, 2014 02:26 PM
marc21387
Jun 18, 2012 11:15 AM
Nenzel
Jan 27, 2005 10:37 PM
kvb78
Bronco II
May 9, 2004 09:53 PM
