My Pickup Won't Start
Old Feb 21, 2016 | 03:26 PM
Luckylady11's Avatar
Luckylady11
Hello, I have a 1986 F150 4x4 with a 302 EFI and we are not getting fuel to the electric fuel pump. That fuel pump and the fuel filter have both been recently replaced. Where should we start checking from there? TIA
Old Feb 21, 2016 | 03:33 PM
JWC 3's Avatar
JWC 3
Do you have dual tanks ?
Old Feb 21, 2016 | 03:37 PM
Luckylady11
Yes it does, we tried both tanks. Not getting fuel from either of them
Old Feb 21, 2016 | 06:01 PM
ctubutis's Avatar
ctubutis
Don't these things have low-pressure in-tank pumps along with a high-pressure pump someplace close to the engine? When you turn the key on, can you hear a fuel pump run for a second or two? Try that test on each tank (using the selector switch on the dash).
Old Feb 21, 2016 | 07:10 PM
Luckylady11
Yeah they do. We have done that. I can hear the high pressure fuel pump run when I turn on the key, but we cant hear the low pressure ones. Did that with both tanks. We also un hooked the fuel line on the pre side and post side of the high pressure fuel pump. When I turned on the key no fuel came out of the line on both tanks.
Old Feb 21, 2016 | 08:07 PM
JWC 3's Avatar
JWC 3
I have seen the selector switch and plug melt . Check for power to the pumps in tank .
Old Feb 21, 2016 | 08:27 PM
Luckylady11
We will have to check that out, thank you. I also just found out that I'm not getting any spark.
Old Feb 21, 2016 | 08:39 PM
JWC 3's Avatar
JWC 3
no spark , no fuel ... Do you have a check engine light at key on ?
Check all fuses .
Old Feb 21, 2016 | 08:47 PM
ctubutis's Avatar
ctubutis
First year of a CEL connected to the computer was 1988.
Old Feb 21, 2016 | 08:51 PM
JWC 3's Avatar
JWC 3
Not aware of that .
Just a thought .
Old Feb 21, 2016 | 09:52 PM
Luckylady11
No check engine light, when I go to turn it on the emissions light lights up. Checked all fuses and they are good
Old Feb 26, 2016 | 09:53 AM
Ziggykennedy's Avatar
Ziggykennedy
Hi Mr Ctubutis,
Wade Kennedy, Ziggy Kennedy, ziggykennedy.wk@gmail.com,having wiring issues book not to helpful, I've done all my own wrenches,only mechanic ever paid was the one that taught me that was home Auto tech Gonzales Louisiana AL James ,my issue with 1986 f150 xlt lariat 5.0 had Short's in wiring harness I have few wire's left to figure out ,I was reading up on your post to other members and it sounds like you really know your s#%t you have expect knowledge would appreciate alot if you had time to assist, I'm new to the site
Old Feb 26, 2016 | 02:50 PM
ctubutis's Avatar
ctubutis
Hi, Wade,
I'm happy to help if I can... but please start your own thread, click the button at the top of this forum (1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums)
arich
15
Apr 23, 2012 09:31 AM
coonbottom
Jan 17, 2012 11:55 AM
Capt_Dunzell
49
Sep 17, 2003 07:24 PM
BOAZTOBALCAIN
Feb 26, 2003 10:18 PM
chrisrog
Jul 13, 2001 12:15 AM
