Painting My Truck
Do's:
Do remove everything you can do get better paint coverage. Why pay $80 an hour when it is something you can do? Remove the bumpers, trim, mouldings, mirrors, marker lights, tail lights/housings, grill inserts, grill shells, antenna, door handles, and anything else that is easily removable and will not be painted. Masking jobs by most bodyshops is usually pretty sloppy and not as careful as if you were doing the masking.
Do a thorough wash-job after removing the above BEFORE turning it in. The more it appears that you care for your rig, then the shop is more likely to respect your property. Plus, there'll be less chance of a spray gun blowing dirt out of some cranny and ending up on your fresh color.
Do bag and ziptie light harnesses left loose from the above steps. It'll keep the primer and color off the bulbs and wiring.
Do keep the tail lights mounted and one side view mirror to be somewhat street legal. You can leave the headlights and buckets installed. Remove the tail lights and side view mirror when you get to the shop. Bag and ziptie the loose pigtails.
Do buy a set of body gaskets/seals for when it is reassembled. Fresh lenses also make a world of difference....It's like putting on a clean pair of socks.
Do budget a 20-30 percent overage on the quoted cost. There's all sorts of lil things that can crop up at the body shop. For example, my Pontiac's bodywork became more extensive because they started tracing the rust.... from the rear end to the wheel arch. That was an extra grand to fix cuz the whole quarter panel needed work.
Do have a detailed work order specifying exactly what you want done and what they will do.
Do call the bodyshop ahead of time if you're gonna stop by to see the progress.
Do ask questions. If they don't feel like answering them or act as if you're an inconvenience or are a hassle, then take your business (and money) elsewhere.
Do inspect the bodyshop you're hiring. The cleanliness of the shop, especially the paint booth, is indicative of their overall attention to detail.
Do install a set of roller wheels and tires that you don't mind getting overspray on.
Do be flexible on a completion date. Shops working towards hard and fast deadlines sometimes results in hurried (and shoddy) work.
Do remove a couple of bed bolts and loosen the other bed bolts' nuts. Remember to tell 'em their loose. The shop will thank you for your consideration. You are removing the bed to have shoot the back of the cab and front of the bed, right? Right.
Do get to know the shop supervisor or foreman and take a look at what other projects they are working on.
Do keep track of your paint code. An OEM color is easiest to match wherever you go.. plus touch-up paint is only an auto parts store away.
Dont's:
Don't be a pest by calling every day, hour, or whatever.
Don't leave the cost open. Some guys I know go have signed off on time and materials and have gotten reamed. Have a signed quote in hand for the work that is specified on the work order. And that any change is subject to your approval. Before signing off on the extra work, go to the shop to do a firsthand inspection of what is causing the extra work. Get a change-order recorded and a written quote. Documentation is important!!!
Don't wash or wax the rig for at least a month or whatever period the painter tells you. Though dry, the paint really needs to cure and outgas thoroughly.
______
Don't forget to enjoy the process and do share your enthusiasm with the shop... I brought them a four cases of beer about a week after I got my Pontiac back.... They remembered me then, and they sure as heck know me now. And now have a relationship with a great shop.
One more tip. Try and find a body man who does work on the side. Most often the rate is lower and you will get the same (or better) results. I do body work on the side and my rate is $35/hour as I have very little overhead.
Be aware that a color change done right is MUCH more costly than a repaint in the same color.
raytasch, thats not to bad for telling them to use it as fill in. I've seen some "fill in" work that has been 2 years or more! If the shop is busy your project may sit for months at a time!
I did an online search about the psychology of color and here's what I found:
- Red
A red car indicates that you are a passionate person. You are a “take charge” kind of individual and you are at least a little wild. If you are thinking of buying a red car keep in mind that red cars are still among the most stolen and one of the most ticketed vehicles on the road. Bright red paint also subconsciously sends the message that the owner is in a higher income bracket. - Orange
An orange vehicle is exceedingly hard to find. Orange says your car color personality is eccentric! If you have an orange car you most likely crave attention. You are also generally a happy and upbeat person who enjoys being unique. - Yellow
There aren’t too many yellow cars on the road either, but a few companies do put them out; think the Ford Focus and VW Bug for instance. If you drive a yellow car you are confident. You like to have fun and you embrace the child within. - Green
Green is the color of nature. The person who chooses a green car is conscientious. They tend to be the go-to person in tense situations because they know how to keep their emotions in balance. - Blue
If your car is dark blue you are likely a very loyal person. You value relationships over wealth and you are calm. Rather than stand out, you like to blend in. If your car is light blue you are serene and peaceful. You also have a strong maternal instinct. - Purple
This is the color of royalty. If you have found a purple car you are a cherished individual who loves beauty, but walks with strength and purpose. - Pink
There are few pink cars out there, but they can be found. If you have a pink car, you like to be treated with a soft touch. You like to smile and you think good health is important. - Brown
If you have a brown car that signifies that you are reliable. You are true to yourself and to those around you. You are earthy and don’t engage in “showboating.” You are approachable, responsible and worthy of friendship. - Black
A slick black car is the epitome of power and authority. Think CIA or Secret Service. If you have a black car, you are sending the message that you are in control and are self-assured. - White
There are many white cars on the road. What they say about their owners has a lot to do with their upkeep. A clean white car shows that you pay attention to detail. You are careful and pure. A dirty white car makes you look sloppy and indifferent. - Gray
Although gray often represents the dreary and depressing in clothes, furniture and paint, that is not the case with your gray car. A gray car is a comfortable one. It represents stability and self-reliance. - Silver
Silver cars represent prestige, wealth and luxury. The newer and shinier the car, the more this will come across. - Gold
A gold car represents wealth and pride. If you have a gold car, you likely want to be noticed. You want people to know you do not lack financially and you are independent.
