Sponsored by: Auxito
NEED S-CODE: 3.55 posi axle with drums
Old Jul 16, 2011 | 07:40 PM
EZFEED's Avatar
EZFEED
Just as stated. If you have one on your truck could you please....PLEASE sneak a peek under your truck and write down the numbers on the tags on your axle. Easy to do, just two tags retained by the diff cover bolts.
I need this to get a new one at a local salvage yard. None of the yards will look for one without having the S-code nor will they let anyone go back to look for parts. Please help!
Old Jul 16, 2011 | 08:09 PM
CollinF's Avatar
CollinF
Just look at the door code. H9 is what you want
Old Jul 16, 2011 | 10:07 PM
EZFEED's Avatar
EZFEED
Is that the S-code?
My axle is a 3.55 regular, I want to go with the posi and that I do not have a door code or s-code for.
I just know they need the numbers off whichever tag has it on the differential.
Old Jul 17, 2011 | 04:33 PM
CollinF's Avatar
CollinF
LS w/ 3.55 is door code H9
Old Jul 20, 2011 | 11:38 PM
EZFEED's Avatar
EZFEED
Just checked it today and H is not a valid code for an axle lookup. The prefix is S hence S code and I tried S-9 but that doesn't seem to be it. Could you sneak a peak on yours?
Old Jul 21, 2011 | 05:56 AM
Scalemandave's Avatar
Scalemandave
Code Ratio Capacity Maker Type
12 2.73 3800 FORD REG
17 3.25 3300 FORD REG
17 3.31 3800 FORD REG
18 3.08 3800 FORD REG
19 3.55 3800 FORD REG
25 4.10. 5300 FORD REG
29 3.55 5300 FORD REG
35 4.10. 6250 FORD REG
36 3.73 7400 DANA REG
39 3.55 6250 FORD REG
45 4.10. 7400 FORD REG
49 3.55 7400 FORD REG
65 4.10. 8250 FORD REG
69 3.55 8250 FORD REG
72 4.63 11000 DANA REG
73 5.13 11000 DANA REG
H5 4.10. 3800 FORD LIMITED SLIP
H7 3.31 3800 FORD LIMITED SLIP
H8 3.08 3800 FORD LIMITED SLIP
H9 3.55 3800 FORD LIMITED SLIP
B5 4.10. 5300 FORD LIMITED SLIP
B9 3.55 5300 FORD LIMITED SLIP
C5 4.10. 6250 FORD LIMITED SLIP
C9 3.55 6250 FORD LIMITED SLIP
D5 4.10. 7400 FORD LIMITED SLIP
F5 4.10. 8250 FORD LIMITED SLIP
W5 4.10 8250 FORD LIMITED SLIP
For example, here's the chart for an 03 F150:
18 — 3.08, non-limited slip
19 — 3.55, non-limited slip
24 — 3.54, limited slip
26 — 3.73, non-limited slip
27 — 3.31, non-limited slip
B5 — 4.10, limited slip
B6 — 3.73, limited slip
H9 — 3.55, limited slip
Old Jul 23, 2011 | 12:12 AM
EZFEED's Avatar
EZFEED
Going to try this!
Old Jul 23, 2011 | 08:30 AM
steve(ill)'s Avatar
steve(ill)
If there is an "S" code, most people dont use it. You parts main aint a very good FORD guy if he cant figure out an 8.8 axle, LS ,with drum brakes.
Old Jul 29, 2011 | 01:53 PM
EZFEED's Avatar
EZFEED
Exclamation
It's not my parts man, it's the salvage yards. Everything is cataloged. Axles are on racks.
If they're on the truck then the H-9 code will work, otherwise I need the axle S-code or they can't locate the axle.
Anyone got it, I went to three yards already and they can't find it.
Old Jul 29, 2011 | 06:06 PM
steve(ill)'s Avatar
steve(ill)
how do they manage to sell anything if they require a code, but they dont know the code.
Old Jul 29, 2011 | 06:10 PM
Ultramagdan's Avatar
Ultramagdan
A easy way to check them if they are on a rack is to just turn one side. If the other side turns the same way, you have a posi. If the other side spins the opposite direction, move on. They can do that and you can verify when they bring it up.
pkulaga
20
May 10, 2006 03:36 PM
77fordguy
Mar 15, 2006 02:41 PM
pkulaga
26
Sep 16, 2005 01:39 PM
pkulaga
30
Aug 8, 2005 04:28 PM
75ford250
Mar 16, 2004 07:52 PM
