Mice ate a lot of my wiring when RV was in storage. I have reconnected what I thought was damaged except for my oil pressure gauge which still is not working.
I'll try to retrace and ring out this wiring but would like to start at the transducer.
Thanks much. it is on the drivers side near the front under the exhaust manifolds. Tough to see but I found that the the mice ate that single wire clear through. Barely had enough coming out of the connector to solder a short piece of wire on.
AND
best of all it now works!!
Thanks for the help I was almost ready to take it to a garage.
