oil light
Old Apr 30, 2016 | 08:31 AM
lnm's Avatar
lnm
oil light
Can someone tell me where the oil pressure sender is on a 390 V8. I changed the oil on my 1973 F100 pickup and then the oil light will not come on. Because when you change oil it makes such a mess on the frame I did wash the oil off around the filter,frame and am wondering if that may have caused the malfunction. If the sender is somewhere around the oil filter I could have bumped or pulled a wire loose also.
Thanks
Old Apr 30, 2016 | 08:46 AM
HIO Silver's Avatar
HIO Silver
It's threaded on the oil filter to block "adapter". Yeah, easy to knock of the wire.
Old Apr 30, 2016 | 09:05 AM
lnm's Avatar
lnm
Are you saying there is some type of adapter next to the oil filter that is treaded into the block.
Thanks
Old Apr 30, 2016 | 09:18 AM
HIO Silver's Avatar
HIO Silver
Originally Posted by lnm
Are you saying there is some type of adapter next to the oil filter that is threaded into the block.
Thanks
No... here is a picture that is worth a thousand words.
See PN 9278? That's the oil pressure switch.
Old Apr 30, 2016 | 03:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's a picture of the filter adapter, the oil pressure sending unit is highlighted. This one is for a gauge, the one for an oil pressure light is smaller, like the one in HIO's illustration.
Old May 1, 2016 | 09:04 AM
lnm's Avatar
lnm
Thank you for help.
Old May 1, 2016 | 09:05 AM
lnm's Avatar
lnm
Thank you for your help.
Dec 9, 2012 11:35 PM
RobbyMartin
1997 - 2003 F150
30
Oct 2, 2010 06:35 AM
Milwaukee1979F150
Oct 18, 2009 10:58 PM
Franken-Truck
20
Sep 13, 2004 02:32 PM
chuckles738
Feb 16, 2003 09:38 PM
